Question about Fisher and Paykel Refrigerators
Fridge/freezer model#e240b fridge freezes up
SOURCE: Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Posted on Nov 25, 2007
SOURCE: fisher and paykel E240B refrigerator
I called F&P customer care when my fridge did this, and apparently 11 beeps means the compressor has failed. I hope you got someone to fix your fridge! I decided to post a solution as I couldn't find one online anywhere!
Posted on Jul 01, 2009
  • 48 Answers
SOURCE: my daughter's mini fridge has a freezer
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Posted on Sep 01, 2009
Testimonial: "We're gonna try the steps you suggested right now. I figured it was something along those lines, but I wasn't entirely sure. Thanks for the help!!"
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
woodchuck789
  • 4059 Answers
SOURCE: bosch fridge freezer not freezing
Make sure the fans are running. One is the condenser fan outside the unit near the compressor at the back. The other fan is the evaporator fan inside the freezer. You may need to hold the door switch in to make it run. If the evaporator coils behind the back wall in the freezer are iced up you may have a defrost problem.
Posted on Sep 14, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My f&p fridge freezer E240B is not chilling in the fridge part. I can't find any manuals or help on line for the product. Help please
Andy,
I am not familiar with the frig your referring to. However, MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped.
Oct 11, 2013 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Frigidaire Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
Sep 01, 2009 | Refrigerators
Fridge section freezes
I would need a model number to even try. Several different ones will probably work.
There are other reasons for the fridge to freeze. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Does the compressor ever cut off? How about when you turn the freezer temp control to the warmer side.
Aug 18, 2009 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Fisher and paykel E240B refrigerator freezer has just started beeping 11 times when i open the door and is not freezing in the freezer cold enough
Aug 18, 2008 | Refrigerators
Oct 24, 2007 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
