Question about Dell Dimension B110 PC Desktop
Clarification I'm not sure, I unplugged a small blue and a small black plug at the bottom of the mother board, a large white plug on the right top as well as the data cable next to it, and a four pronged plug just above the hard drive.
  • Deboo Geek May 11, 2010
    If it's an old PC, the four pronged plug might be the floppy drive power connector. Not sure about the other plugs - you might need some hardware engineer to visit you to help.
    Is your PC working after all this? Or giving any error?
  • Dan rogers
    Dan rogers May 11, 2010
    ok is the data plug plugged back into the same slot it came out of?
    Sorry to have to ask but do you know what the difference between seta and IDE is??
  • 3,940 Answers
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Tip
PS3 (Playstation 3) Yellow Light Of Death REPAIR GUIDE
Disclaimer: if your PS3 is still under
warranty then please send it back to them for repair.
DO NOT Try this repair IF IT IS STILL UNDER WARRANTY.
This Guide is for the repair of *********** boards only and
will not repair your power supply or read errors.
In this guide there is no guarantee you will fix
your ps3 and by following this Guide YOU take on full
responsibility for any damages caused by following this guide.
Tools needed
Heat gun .
Isopropyl alcohol.
Vacuum cleaner or compressed air can.
Phillips screw driver.
Flat Head screw driver or slotted torx bit.
Artic Sliver 5 (Radioshack)
1. Remove warranty sticker and rubber foot that’s
positioned above hard drive bay.
This will invalidate any warranty.
2. Using a small flat blade screw driver or slotted torx bit,
unscrew cover plate screw.
3. Slide cover plate towards the left until it stops and lift
off.
4. Remove all Phillips screws marked noting size and
position.
5. Hinge case towards you until disengaged and then tilt
towards the left. See below.
6. Remove ribbon cable by carefully lifting black part of
connector (locking tab).
7. Lift/tilt blue ray drive towards the right whilst
disconnecting power cable and the large ribbon (lift tab)
underneath.
8. Remove 5 screws and the earth wire screw on psu, and
unplug connector plug.
Before removal of psu unplug small bnc connector (black
wire) and remove tape on side of psu, now lift off psu.
9. Now remove the wide ribbon from connector (lift tab)
unscrew the four screws on the Bluetooth board and
remove.
10. Remove hard drive cover,
11. Unscrew blue hard drive screw and disengage hard
drive by sliding towards gap in the bay. .
12. Remove hard drive,
13. Unscrew 4 screws holding the bracket, on/off and
eject control panel.
Remove small ribbon (lift tab) and remove control panel.
14. Unscrew 8 screws,
15. Lift enclosure out of plastic base,
16. Now unclip black rear panel and remove.
17. Unscrew 4 screws and remove sprung brackets,
18. Lift of metal cover plate whilst allowing ribbons to
pass through gaps in plate without damage, see below.
(Taking note where heat sink rubbers are positioned).
19. Supporting fan assembly turn board over, remove
fan power connector and fan,
20. Remove 2 screws holding plate to hard drive
connector and unplug battery connector. See above.
Now remove plate.
21. Clean off old heat sink compound from the 2 main
processors using Isopropyl alcohol Or Artic Silver remover Faster Than alcohol)
making sure all traces of the old heat sink compound has gone.
22. Clean both touch plates on bottom of fan/heat sink
assembly with Isopropyl alcohol until all traces of the old
23. Now using a vacuum cleaner or compressed air
blower get rid of all dust build up in the case and on all
component parts of the ps3 (pay special attention to the
fan assembly and heat sink fins(MUST BE CLEAR OF
DUST).
24. Place the ps3 mother board on a flat heat resistive
surface (kitchen work top or melamine shelf will be fine).
25. Turn heat gun on and set temperature to 350 deg
and the fan speed to low (to high and it will move the
surface mount bits).
Allow gun to get up to temperature before
continuing!!!!
Note (There is two Large Square Chips in the Middle of the board these are your CPU and GPU they both have two Black Rectangles Right Next to them. These are the Memory Chips. These are the only things you will be Heating Up on top and Bottom)
26. Using a circular motion hold heat gun over areas
outlined below (keep heat gun an inch above
board/components at all times).
27. CPU side first.
. After 15 to 20 seconds move onto the next area.
28. Once all marked areas have been heated/reflowed
on the mother board LEAVE for at least 10 to 15
minutes to cool.
(DO NOT MOVE MOTHER BOARD WHILE COOLING).
29. A popping noise may be heard during cooling, don’t
worry this is normal.
30. NON CPU side.
31. After 10 to 15 seconds move onto the next area.
32. Once all marked areas have been heated/reflowed
minutes to cool.
33. A popping noise may be heard during cooling don’t
Heat sink compound still on in this picture, remove
before reflowing.
Heat sink rubber pads still on in this picture remove
before reflowing also hold ribbons out of way while reflowing;
You have just repaired you’re yloded ps3
mother board.
34. Now its time to apply new heat sink compound to
the 2 processors, when doing this its always best to
follow the manufacturers instructions but I believe the
process is the same with all types (please check
instructions that come with paste), before continuing
35. Now Get your Artic Silver 5
36. Place a Small amount of compound from top to bottom on the left hand side of
processor chip, now using a finger with some Plastic over the tip spread the
compound evenly and thinly over processor face (to much
is bad and not enough is also bad) the ideal amount is
when you can almost see through the paste.
37. Now repeat on the other processor.
38. NOW IT IS TIME TO REASEMBLE THE PS3.
RETRACE YOUR STEP IN REVERSE TO REBUILD
MAKING SURE ALL RIBBON CABLES HAVE BEEN
FULLY INSTERTED INTO CONNECTORS AND LOCKED
DOWN IN. (TABS).
on Dec 15, 2009 | Video Game Consoles & Games
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Where is the defrost timer locate
The timer is the main control board behind the refrig , behind the 8X10 panel . If you have a defrost problem , Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
I have never found a control board causing a defrost problem .
Aug 04, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Mar 05, 2010 | Janome Memory Craft 9000 Computerized...
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
Picture is showing in BLACK AND WHITE now. Can I buy just the COLOR WHEEL iot repair unit??
yes. part number 525-0146-00. you can get it through any infocus authorized service center. some won't sell parts to you. try av solutions in rochester, ny. i know they will.
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
Oct 05, 2009 | InFocus ScreenPlay 4805 Multimedia...
The back wall of my fridge is freezing up... I had a repair man replace two sensors and to no avail then I replaced the mother board and that did not work either... what now?
Unplug the refrigerator . Remove the motherboard cover . Remove the blue plug with large wires from the motherboard . Looking at the plug , you'll see wire1,wire2,space,wire3 . Using a short piece of wire with both ends striped , insert the ends into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom of the rear wall , for a red glow . May take several min . If no red glow , replace the defrost heater AND the defrost thermostat (bimetal ) . If red glow , bad control board .
The defrost heater and bimetal , are behind the rear lower panel inside the freezer section . The heater is at the bottom of the coils , and the bimetal is clipped on at the top of the coils ( blue and pink wire ) .
Sep 06, 2009 | Refrigerators
Dell Dimension B110 PC Desktop Logo
Alun Cox
