Question about HP iPAQ RZ1710 Pocket PC
Hp pda ipaq rz1710 doesn't know to used
I bought a pda hp ipaq rz1710 in ebay and no manual and now i'm confused how to used it even the basic ones needed help badly can u help me pleaseeeeeeeeeeee?........
How i can transfer data from pc to iPAQ bcz i lost my cd
Posted on Dec 12, 2008
Download the manual off the HP site. It's FREE
Posted on Aug 21, 2007
SOURCE:
Hewlett packard ipaq rz 1715 bought pda on ebay. I need a manual
Please download it from here...
http://mikechannon.net/holdingfile/HP_iPAQ_rz1710_User_Manual_EN.pdf
Jul 25, 2011 | HP iPAQ RZ1710 Pocket PC
Looking for a manual for a HP iPAQ rz 1710 Pocket PC
Look here, and download the user manual you need.
Cheers! Carlos
Apr 30, 2010 | HP iPAQ RZ1710 Pocket PC
I can figure out how to use my hp foldable keyboard with my pda do i install a driver or something?
You may need to turn n the Bue Tooth and pair the devices together. The manual that came with the device should give you some pointers
Oct 15, 2009 | HP iPAQ RZ1710 Pocket PC
I let my hp ipaq rz1710 die and now it will not work
try taking the battery out for about a minute and see if that restarts it.
Apr 24, 2009 | HP iPAQ RZ1710 Pocket PC
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
Rz1710
try to erboot it, there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Dec 18, 2007 | HP iPAQ RZ1710 Pocket PC
HP Ipaq rz1710
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Sep 16, 2007 | HP iPAQ RZ1710 Pocket PC
HP IPAQ RZ 1710
try to connect to ur PDA harddrive where u have uploaded those files via ur PC sync conn. and delete them
Sep 09, 2007 | HP iPAQ RZ1710 Pocket PC
Ipaq RZ 1710 won't switch on
If you've backed up your PDA, I'd strongly suggest trying a hard reset. This has happened before to one of my RZ1710 pda's. The only solution was to hard reset it. This can be done by pressing the two extreme left and right buttons (The Calander, and Home button) and the reset button on the bottom of your iPaq with the stylus.
Sep 11, 2005 | HP iPAQ RZ1710 Pocket PC
HP iPAQ RZ1710 Pocket PC Logo
273 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
