Question about White Sewing W3300 Computerized Sewing Machine
Fixing my white 3300 embroidery machine
Same problem I see with many; in that my needle will not pick up the bottom thread (timimg off?) and prior to that my bobbin thread was bunching up. After I cleaned the area out it started messing up. I really can not afford to service it and would be willing to pay a small amount to watch an on line tutorial to fiix it.
  • White Sewing Master
  • 1,564 Answers
First change that needle, it's probably bent. Then double check the bobbin/shuttle area for threads wrapped around moving parts.
Posted on Nov 06, 2012
3 Suggested Answers
  • 1116 Answers
SOURCE: I have a WHITE 3300 EMBROIDERY MACHINE and the
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Posted on Mar 18, 2010
  • 4 Answers
SOURCE: Top thread won't catch the bobbin thread
First check the upper and lower tension adjustments according to link below and then check the knob (bobbin case) that makes the bobbin tension which lies inside the shuttle if it is too loose. Restricted it with the sheet metals around it so that it shouldn't move so freely up and down or back and forward. Be careful it should move freely a little but not too much.
http://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
@ytac...
Posted on Feb 24, 2010
In regular sewing my stitches are fine but when I switch to embroidery the top thread is loose and sometimes doesn't pick up the bottom thread. What can I do to fix this?
You may need to have it checked and tuned up. It doesn't cost much. I just had mine done for the first time because when I tried to wind a bobbin the needle stayed in sewing status. I bought this machine years ago and it only cost.80.00 for a tune up also.
Looking at the manual it says to go to auto and you can see the screen where the cloth guide position can be adjusted. Right under that is the auto tension with a + and -. You would need to increase the tension level. It says that this is also used for professional style embroidery in the same way.
I hope both of these suggestions will help.
Jun 03, 2014 | Janome Memory Craft 9000 Computerized...
My top thread does not pick up the bobbin thread. I broke a needle in it the other day and replaced the needle and now having trouble with the bobbin thread. It is not turning? I am very new to embroidery....
Take off your throat plate and make sure that there is not a piece of your needle still in there, brush it out and oil your machine if it needs it. Now rethread.
Apr 21, 2011 | White Sewing White 4400 Computerized...
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
@ytac...
Feb 24, 2010 | White Sewing W3300 Computerized Sewing...
I have a White 3300 embroidery machine not catching bobbin thread
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
White Sewing W3300 Computerized Sewing Machine Logo
318 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
