Question about Exercise & Fitness
I have a Golds Gym Crosswalk 570. It powers up fine but the console only shows zeros when the key is in and none of the buttons work. I've tried doing the stop and speed up button but no luck. The red control unit light is solid. When I manually walk on the treadmill the speed does change so it seems the cord is fine. When the key is out it shows demo numbers. Does anyone have any other suggestions?
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
  • 10865 Answers
SOURCE: Gold's Gym Crosswalk 650 Treadmill belt stops
Hello. Either there is too much load for the motor, or the motor is weak, or the controller in failing and unable to adjust for changes in resistance.
By far the most common problem is too much load. Do the checks in your manual to be sure the walk belt is not too tight or dry. Also check that the motor belt is not too tight, you should be able to twist it 90 degrees. If you loosen both belts until they just begin to slip and then retest you might find the everything is okay which indicates the walk belt may need lubing or replacing. If the walk board under belt looks pitted, grooved, or distorted it also would need replacing.
If the unit passes the tests above and a push test then the problem will be in the motor or controller or possibly both. If the motor passes a walk/voltage output test then it might be okay and you might only need a controller. Unfortunately, it is common for a failed motor to damage a controller and vice versa, and that damage might not show up immediately, so you if one has failed you might consider replacing both.
Posted on Mar 22, 2010
SOURCE: Treadmill speed control does not work - only max.
MY CROSSWALK 3.0 XT WILL ONLY GO UP AND DOWN. IT WILL NOT DO ANYTHING ELSE. PLEASE HELP!
Posted on Jul 26, 2010
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
SOURCE: Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Posted on Feb 25, 2011
I have a Golds Gym Crosswalk 570 treadmill and the screen reads P 26 E 6 82. The belt won't operate and the screen freezes. Any ideas?
More than likely coming from either your controller or upper board.
www.atlantafitnessrepair.com
Oct 18, 2015 | Exercise & Fitness
Maintenance
the walking belt needs to be lubed with a good silicone lubricant. this is put under the walking belt
Aug 21, 2014 | Golds Gym MAXX CROSSWALK 650 TREADMILL...
IFit control Panel on Gold's Gym Crosswalk 570
go to the web site they a LOT of tool +software update for you ifit
http://support.ifit.com/home
God bless you
Feb 07, 2013 | Golds Gym CrossWalk 570 Treadmill
Crosswalk 570 goldsgym...we cannot get hood cover off...there are 3 screws in front...will not come off..please give me directions
Use the WD -40 spray it and wait by 30 minutes for to loose, and use some wrench or drill with the appropiate tool for to screw off.
God bless you
Nov 19, 2012 | Golds Gym R CrossWalkR 570 Treadmill
My Golds Gym trainer 480 treadmill wont start and none of the buttons work except for the up and down arrows for the incline.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
Oct 20, 2012 | Exercise & Fitness
Golds gym crosswalk 650 no control.
Call the manufacturer at 877-776-4777.
Jan 17, 2012 | Exercise & Fitness
I need the manual from golds gym crosswalk 570
go to www.iconservice.com give you model, etc and download for free.
sincerely. Happey new Year.
ernesto cuadra
managua, nicaragua
Dec 25, 2011 | Exercise & Fitness
Exercise & Fitness Logo
115 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
