Question about Powerspec G213 Desktop Computer; Intel Core i7-3820; Microsoft Windows 7 Home Premium 64-bit; 16GB DDR3-1333 RAM; 2TB 7,200RPM Hard Drive; 12X Blu-Ray DVD Burner Drive; 8-in-1 Digital Card Reader; 2 NVIDIA GeForce GTX 550 Ti; 2 10/100/1000 Network; 802.11b/g/n
Remove a ssd from powerspec g213
I thought that removing an ssd from my Powerspec g213 would be as straightforward as removing a sata drive. I have disconnected the power and sata cables from the ssd but it doesn't budge when i try to slide it out of its bay. I don't want to force it so I though I'd ask here how to remove it. After I remove it I will install a new one with higher capacity.
There is a grey x shaped knob near the outer casing in the slot your drive is mounted, turn the knob counter clockwise and presto you can remove your dive !!!!!!!!
Posted on Mar 21, 2013
What remote control works for a powerspec tv
I am not familar with powerspec tv, but logitech makes programable remotes that can control many different components. check thier web site for info on the remotes and you can ask them if it will work.
Aug 06, 2014 | Televison & Video
Power spec 6342
WinBook PowerSpec 6342 Specifications The specs for PowerSpec 6342 comes in these configurations with a retail price tag. The configuration WinBook provides comes with a 3.06GHz Intel Celeron D 346 n/a Serial ATA, Ultra ATA/133 PCI/AGP 160.0 GB Windows XP Home SP2, S3 Graphics Unichrome PRO 128 MB DDR 128 MB DDR (shared).
This WinBook Computer can take up to 2.0 GB ram, with a fixed amount of 512 MB (removable) installed PC3200 DDR SDRAM DIMMs.
This full-featured mainstream Computer enhances the previous generation WinBook models with the chipsets and new levels of customization. Get the best experience on your WinBook PowerSpec 6342 Computer with improved performance, make it easy to create a home network and share all of your favorite items.
The specs of Computer shows full configuration information. The PowerSpec 6342 is designed for users who require maximum performance in a mainstream Computer. Even with its form factor design, the PowerSpec 6342 doesn't skimp on performance offering the ideal blend of power and efficiency.The PowerSpec 6342 is sure to leave a lasting impression with its easy to use and slim design. Located on the side of the unit, the modular bay's innovative latch is designed for easy insertion and removal of the various module options.
The PowerSpec 6342 Computer only supports 3.06GHz Intel Celeron D 346. The PowerSpec 6342 features two on-board data caches for transferring information to and from the processor. These caches are known as the L1 and L2 caches. The PowerSpec 6342 L1 cache is 64 kilobytes in size, while its L2 cache is rated at either one or two megabytes.
When you have a clear idea of which Computer best suits your needs, check for its specifications. As the PowerSpec 6342 is supported by WinBook, check if the Computer has full support and warranties by its manufacturer, like PowerSpec 6342 specs you will have lots of options from the Computer manufacturer to choose from, like the Computer processor, Computer RAM, its graphics capacity, Computer display options and specs, and other features that the Computer provides. You should have an idea on what specs you want from your Computer and what specs you do not want on your Computer, deciding on Computer specs may be difficult task to do but like the PowerSpec 6342 specs have, it's essential to selecting a Computer you need at a price tag that it deserves and that you can afford.
Here is a sample PowerSpec 6342 Computer specification if you want an initial guide to buy a Computer. More or else, these are the specs factors often that you should take into consideration before you purchase a particular type of Computer. To help you navigate around the hassles of buying a Computer, we have the standard specifications for most home and small business users.
Jun 11, 2014 | Computers & Internet
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
Powerspec b820. How do I add a new HDD
>Power down, and unplug the computer.
>Remove the Left cover (when facing the front); there are 2 thumb screws top & bottom on the rear. They go through the black edge of the cover and thread into the case. The side cover pops off.
>Locate the hard drive, unplug the two SATA cables (power and data) from the hard drive; leave them plugged into the motherboard.(see picture)
>There are two screws that hold the HDD (Hard Disk Drive) in the bay; remove them. There may be two on the other side (sometimes not). If so, you will have to remove the other side cover in order to access them for removal.
>The HDD will slide out the rear of the bay.
>Slide in the new one, reset the screws, replace the cables, and put the side cover(s) back on.
You're done and ready to format and install your operating system.
See the attached picture for clarification.eaa0cf82-6180-4457-87ca-281f3b46185a.jpg
Oct 07, 2013 | Powerspec B820 Desktop Computer; Intel...
How do I remove a power spec hard drive
It is a Mini-tower, so chances are you will need to remove a cage that it is in, and then remove the drive from the cage. Hard to tell, though there are no pics online.....no manual either.
Aug 20, 2012 | Micro Electronics PowerSpec 8420 PC...
How to open drive bay to add floppy drive
Floppy drive?? Why? Are you installing Windows 3.1 from 1990?
You would have to remove the sides off your PC, possibly pop out a drive bay cover from the front panel of your case, slide in the floppy drive, fasten it with screws and wire it with the appropriate cables which rarely ship with modern motherboards these days.
May 12, 2012 | Micro Electronics PowerSpec 4820 PC...
Manual for Powerspec Computer V100
Hi. Your mainboard is an ECS 945G-M3
Here is the manual for the mainboard:
http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/945G-M3%20(3.0).zip
And the mainboard manufacturer website:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=680&DetailName=Feature&MenuID=1&LanID=0
If you want info about the Tower in general hare is a link to the V100 page on the Powerspec website that will tell you about the components they used to build the system:
http://www.powerspec.com/systems/archives/system_archive.phtml?selection=V100
Hope this helps... Dale
Apr 22, 2011 | Computers & Internet
PowerSpec 6245: get logo screen and freezes. no
i think your system facing hang problem .plz check out your pc with any technical person.
Jan 22, 2010 | Micro Electronics PowerSpec 7320 PC...
I just bought a new powerspec g207. When I try
this computer has two hard drives which are raided together to become one. you must first run the RAID drivers disk before trying to install 7.
Jan 16, 2010 | Computers & Internet
Powerspec G213 Desktop Computer; Intel Core i7-3820; Microsoft Windows 7 Home Premium 64-bit; 16GB DDR3-1333 RAM; 2TB 7,200RPM Hard Drive; 12X Blu-Ray DVD Burner Drive; 8-in-1 Digital Card Reader; 2 NVIDIA GeForce GTX 550 Ti; 2 10/100/1000 Network; 802.11b/g/n Logo
160 people viewed this question
Top Powerspec Computers & Internet Experts
David Payne
David Payne
Are you a Powerspec Computer and Internet Expert? Answer questions, earn points and help others
