Question about Dehumidifiers
Dehumidifier not collecting water
It seems that everything works on the unit but no water is collected. What could cause this? I have set it from the lowest setting to the highest. I have let it sit unplugged, I have taken off the back panel to see if there was something disconnected or corroded.
Its about 7 years old but was working up to a month ago.
  • Anonymous Jan 03, 2009
    Ours is a brand new unit, and the same problem.
  • Anonymous Jan 05, 2009
    hi,i have the same problem the pipes are freezing, but there is no water in the tank?
  • 4 Answers
Most probable cause of a dehumidifier not collecting water when it appears to run fine otherwise is a dirty heat exchanger. It is unlikely that a huge spread in the time a unit works is caused by failure of the compressor of loss of refrigerant. On the other hand, people use their units in very varied conditions of dust in the environment with expected short to long operating times before failure. Here's how to fix this problem in two steps.
Step 1: Determine if your compressor and refrigerant sealed unit is operational
Step 2: If Step one is negative, dispose of the unit - specialized equipment is required to repair or recharge a compressor. If step one is positive, then clean the heat exchanger.
This site did not allow me to post the full instructions because they exceed an unspecified upper limit to message length. What a waste of time. In order to be helpful, please contact me at j_sjohn@hotmail.com and I will email you a file with a complete set of instructions. Cheers.
Posted on Jan 05, 2009
It seems that everything works on the unit Danby DDR4007EE dehumidifier but no water is collected. What could cause this? I have set it from the lowest setting 35% and it always shows from 57 to 64%. I have taken off the back panel to see if there was something disconnected or corroded. I never collected one drop of water since 3 years.Nothing is cool at the back when i touch every where.
Could you help me to solve that problem at a low cost .
thanks
Regent
St-Hubert,Longueuil
Posted on Jul 13, 2010
  • regentlavoie Jul 13, 2010
    thanks
    Regent
    St-Hubert,Longueuil
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
heatman101
Feb 07, 2011 | DeLonghi DH40P Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
DEM 10 Delonghi Dehumidifier has Stopped collecting water but still seams to be working
Take care.
Aug 14, 2010 | DeLonghi Dehumidifiers
The Dehumidifier is not collecting water. How do you get this fixed?
Good luck.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
My dehumidifier has not, does not collect any water. HELP !
Take care.
Aug 10, 2010 | Amcor AHD45 Dehumidifier
Unit not collecting water
Good luck.
May 15, 2010 | Soleus CFM-40 Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Dehumidifiers Logo
963 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
