Question about McCulloch Garden
My McCulloch MB 290 runs for 5 minutes and then shuts down. Mix in the tank is 1 month old but is correct.
  • 430 Answers
Could be several different things. Carry a can of carb cleaner with you and run it till it quits. Then remove the air box and try to start again, try using the choke, try a squirt of carb cleaner in the carb ( not at the same time ). If it tries to run then its a fuel issue or an air leak. If it wont run then its got low compression or a bad ignition.
Posted on Oct 25, 2012
4 Suggested Answers
Editor925
  • 285 Answers
SOURCE: what is the fuel mix
Ratio is 25:1
Posted on Feb 14, 2011
  • 6 Answers
SOURCE: Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Posted on Mar 20, 2009
  • 110 Answers
SOURCE: What is the mix ratio of a McCulloch 90 chain saw
I would say if its within the last 0 years use a good brand synthetic 2 cycle oil at 50 to 1, Echo and Husqvarna atr top quality, avoit the store brands and shihl oils
Posted on Oct 31, 2009
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What would be the recommended gas/oil mix for a mcculloch pro mac 610 chainsaw
40:1 (3.2 oz/1 gal) per the manufacturer.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
I'd use 50:1
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 01, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the proper fuel mix ratio for a mcculloch eager ****** 14" chain saw?
Fuel/Oil Mixture
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 20, 2009 | Garden
Does 2 cycle oil get mixed with gas on McCulloch chainsaw or just put gas in?
Fuel/Oil Mixture
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 14, 2009 | McCulloch Garden
What is the fuel mixture for the mcculloch 3216 chain saw?
Fuel/Oil Mixture
    Lou
Oct 13, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the gas/oil mix for a mccullock 120? Thank you Carl
Fuel/Oil Mixture
    Lou
Sep 28, 2009 | McCulloch Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Spark plug for mcculloch 2014 2.0ci and what is oil to gas mix
Not sure about the spark plug but the mix:
Any quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 years ± 50:1 (Stihl 2.6oz/1gal)
Today most gas in the US of A contains ethanol; not good with chainsaws. mix what expect to use within a few months. Anything over 6 months use up in a 4 cycle engine. HTH
Lou
Sep 10, 2009 | McCulloch Garden
Garden Logo
250 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
