Question about SySTOR Systems (400S52) Burner
Burner will not light
Carlin commercial burner-oil fired model 701-CRD
High gas pressure switch reset
Posted on Jan 21, 2013
You need to tell me what the burner is doing when it starts up. Some basics to look for:
1- bleed pump of any air- is it a new install? 2- If you are getting fuel, are you getting spark on the electrodes? 3- if you are, you may need to adjust draw assembly air, and or air intake per Carlin specs.
Posted on Jan 16, 2009
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
MacBook Pro often will not recognize commercial DVDs
Go to MAC's website and see if there are any driver updates for your MACBOOK Pro.
Oct 25, 2009 | Apple Genuine Pioneer "SuperDrive"...
Lightscribe not detected
go to lighstrcribe.com and dowload all the software there.
there are special programs/drivers there that you need to have.
then reboot and nero should pick it up
Apr 24, 2009 | QPS Que! Fire CD-RW Burner
Furnace rumbles when it turns on
varies from burner to burner to burner , should replace with the same as you removed , the numbers are very important on the nozzle one of the numbers is the degree of the fire pattern the nozzle produces ex. a 90 degree or 80 degree etc . this is determined by the way the fire box in the furnace is insulated . the other number is gallons per hour of oil the furnace is set up to use , ex. .70 gph or .80 gph all of these numbers are critical and should not be changed except by an expert or you could damage your furnace and could possibly be dangerous . the numbers will be on your old nozzle and should go back with same one , as to the adjustment , they also vary ,but i can give you one that will usually work for most furnaces , that is one eighth inch space between electrode tips , five eights in front of nozzle port opening , and one half inch above center of nozzle center , where the hole is . bleed all air out of system after installing nozzle , let me know if no fix have more ideas
Nov 21, 2008 | SySTOR Systems (400S52) Burner
Oil Burner Will not Ignite
my burner will not light mpdel 701-crd. carlin
Nov 07, 2008 | SySTOR Systems (400S52) Burner
Assus external cd/dvd rom
Hl
You must buy asus external drive its worth
Harry
Oct 31, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Won't scribe
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-clickon Lightscribe Service, and if it says disabled change it to automatic,then "start service" in the left pane if is already started and set toautomatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
Oct 23, 2008 | QPS Que! Fire CD-RW Burner
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Brand new Super Multi DVD Rewriter model GSA - H55N
Are you copying commercial DVDs? What you are seeing is indicative of Macrovision encoding...accordianman
Feb 28, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Computers & Internet Logo
212 people viewed this question
Top SySTOR Systems Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
