Question about Troy-Bilt 4 Cycle Straight Shaft String Trimmer TB575EC
Gas dripping out of air intake on troy bilt trimmer TB525EC
Runs fine, starts every time
  • steve bertrand Oct 27, 2012
    trimmer is only 2 months old. used 6-7 times. i use gas stabilizer so the gass is good. call troy bilt for help, may as will have called PeeWee Herman.
  • 430 Answers
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Posted on Oct 25, 2012
  • steve bertrand Oct 26, 2012
    I need to use the chock when starting it every time. The trimmer is only 2 months old used around 6 times. I use stablizer in the gas
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 4 Answers
SOURCE: changed fuel line on my troy-bilt gas trimmer
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Posted on Apr 24, 2010
jyackle5
  • 8197 Answers
SOURCE: Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Posted on Jun 27, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Puolan pro idles fine but quits when I give it any gas. It's quite new and just started doing this after it ran out of gas and sat a few days before I got some gas in it.
sounds like a float or jet clogged problem. If no carb on this model, then remove fuel line and blow it out. Also check air intake for obstuctions.
Jul 04, 2009 | Troy Bilt Tb70ss Gas Trimmer
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need to clean carburetor of troy built trimmer. Where can I find directions on how to do it?
Go to any auto parts store and buy an aerosol can of carbeurator cleaner. Remove the air cleaner filter and give the air intake a couple of squirts. Pull the cord and turn the engine over a couple of times to draw the cleaner into the carb. Then let it sit for an hour and dissolve what ever is gumming up your carb.
Jun 11, 2009 | Troy Bilt Tb70ss Gas Trimmer
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Trimmer will not start.
Yes. Your carbeurator is gummed up. Get some new gasoiline and add some carbeurator cleaner to it, usually one ounce per gallon. Dump the fuel u have in there and put in the new fuel.
Also, get some spray carb. cleaner, remove the air filter and put a couple of squirts into the air intake chamber. Then start it.
Finally if it still won't start, use a squirt of starter fluid to get things going and get the carbeurator cleaning into the system.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt 4 Cycle Straight Shaft String Trimmer TB575EC Logo
270 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
