Question about John Deere Garden
John Deere LX173 pto will not engage. Wet recently
Runs fine and pto worked before being left out in recent heavy rain. Will not engage now
  • 430 Answers
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Posted on Oct 25, 2012
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 153 Answers
SOURCE: Battery lite glows when pto is engaged after running for 5min
The charging circuits used on smaller tractors are generally barely adequate for the load presented to them, so it is important that the tractor engine is running fast enough especially when using PTO power. If your tractor has a tachometer on it, JD has an indication of the motor speed you should use when using the PTO. If not, it is generally pretty close to max. It should sound like it is running smoothly although fast, and not with whining or rough sounds from the engine.
Posted on Apr 30, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Were do you check the transmission fluid on a john deere lx173 lawn tractor?
i am not familiar with John Deere but most lawn tractors dont have a way to check the fluid they are sealed.
Sep 04, 2017 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Problem with John Deere L120 tractor
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jd 3020 power shift pto turns all the time. if lever not engaged a heavy load can stop it. otherwise it works ok
The pto brake is either worn out or you have no presure to it when the pto is turned off,most likely the pto brake is worn out.
Nov 03, 2009 | John Deere 3010,3020 Tractor Basic...
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Garden Logo
1,045 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
