Question about GE GMOG28ECPS STAINLESS STEEL MICROWAVE OVEN FOR 220 VOLTS
How do you change the clock on a GE GMOG28ECP(A)SS Stainless Steel Microwave Oven?
  • GE Master
  • 9,098 Answers
You can download GE owner's manuals and installation instructions here.
Posted on Oct 26, 2012
3 Suggested Answers
SOURCE: looking for a G.E. microwave trim kit
I ordered a trim kit from a on-line group who will make it to fit your needs. I can't think of their name but you can find them by doing a search. I ordered the black to go with my SS mic/conv oven and it looks great. Was not difficult to install.
Posted on Jul 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
I have a GE Microwave Oven, model JKP90DPBB. The microwave appeared to have overheated the other night because I turned around to use it and it was dead / off (no working functions). Since then, it kicks...
"Built in" microwave ovens I've come across are all hung from the top of the oven, so you'll have to get above it to drop it out with help in all likelihood. Yours sounds like it may have a faulty connection to power either internally or at the plug. Dont use it like that. You will either destroy it or maybe even cause a fire.
Oct 11, 2017 | GE Microwave Ovens
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
Unsightly film on microwave after cleaning with bleach.
Purchase a stainless steel cleaner from anywhere. They usually have lemon oil in them that leaves a nice shine on the surface. You can even use furniture polish in a pinch it is about the same. An oil free choice would simply be window cleaner and paper towel. My moms old fashion secret to no streaks was newspaper for drying with. Works great. Good luck.
Feb 15, 2011 | GE JVM2052 Stainless Steel Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
Need replacement glass turntable
looking about $65 from jacobyparts.com and and sears parts
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Looking for a G.E. microwave trim kit
Your best bet is to call GE Parts & Accessories at 1-877-959-8688
(Mon-Fri 7am - 6pm CST, Sat 7am-4pm CST)
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE JVM1790 1000 Watts Convection /...
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
GE GMOG28ECPS STAINLESS STEEL MICROWAVE OVEN FOR 220 VOLTS Logo
307 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
