Question about Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light
My Makita saw is sending out blue smoke as I do bevel cuts. Is my saw dying and what can I do about it? Thanks
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Have a makita quick cut saw but site requirements
go to Makitatools.com and type in your model number which is DPC7311 and you can download the owners manual for this tool. If I have helped with your request would you please rate this response accordingly. Thank you
Posted on Feb 17, 2010
  • 18 Answers
SOURCE: Saw cuts bevel at 0
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Posted on Aug 13, 2011
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
I was using my saw and the large spring popped out, how to reinstall it (makita dual bevel compound saw)
just found the problem, if you haven't fixed it yet let me know. There is no good way to reinstall the spring but I have done it numerous times and can talk you thru it, but you will need a press of some sort.
Aug 18, 2010 | Makita 10" Dual Bevel Sliding Compound...
My blade won't cut threw the intier stock. like somthing is stoping it from breaching the deck. There is no saw dust hindering it anywhere and it used to cut right threw.
turn the bolt counter clock wise on the arm, this will allow the blade to go lower...don't go too far or u will cut into the base and or fence.
Aug 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
I have a craftsman radial arm saw 113.23100 which has not been used for possibly 20 years. I cannot get the motor to rotate in order to make 45% angle beveled cuts. I have turned the bevel lock knob to the...
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Jun 27, 2010 | Skil 10" Table Saw
Gaurd will not release up smoothly, the gaurd will hit the table top not alowing saw to complete cut
for what brand and model, if this is a Makita the link bar and the plate that it rides on are possibly worn and need lubrication or replaced, also check the bolt holding the guard in place to make sure fully seated and tight Let me know and I will try and help.
Mar 13, 2010 | Makita 10" Dual Bevel Sliding Compound...
Not cutting square
You might have an adjustment on the swing arm itself, for fine tuning the cut. If you still have the manual, it should give details.
Jan 30, 2009 | Makita 10" Dual Bevel Sliding Compound...
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Dual-bevel Features
Dual-bevel capability allows angled cuts in either direction without flipping the workpiece
Aug 27, 2008 | Makita 4323K 3.7 Amp Jig Saw with Case
Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light Logo
50 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
