Question about Mitsubishi WD-65833 65" HDTV
How to change the dlp chip - Mitsubishi WD-65833 65" HDTV
Go to YOUTUBE type how to change the dlp chip and your tv model and there will be a few videos.
Posted on Jan 19, 2014
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Dlp chip replacement
1910-6003 Does not look like a good part#
The correct part# 276P595010 Dlp 1910-6143W
www.aaatvservice.com
Aug 14, 2014 | Mitsubishi WD-60735 Projection Television
Wd-65734 dlp chip can't find part for can we change it or better off to buy a new tv?
The part# for this DLP chip is: 276P595010 ( DMD-CHIP:IC-1910-6143W)
http://www.shopjimmy.com/mitsubishi-276p595010-dlp-chip-dmd-ic-new-original.htm
$189.99 + shipping you can shop around for better pricing
I DO NOT recommend this to be replaced by a DIY. I highly recommend an experienced technician replace this as you could make matters even worse if you don't know what you are doing.
so consider your labor costs involved & you may want to invest that money in a NEW LED or LCD TV.
Jul 22, 2014 | Mitsubishi Televison & Video
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
White spots on samsung DLP tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Apr 27, 2010 | Samsung HL-R4264W 42" DLP HDTV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots are just emerging on my 50 inch Samsung DLP TV everyd
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
http://www.discount-merchant.com/SearchResults.asp?Search=dmd
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
Jul 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
