Question about Sony CCD-TRV238 Camcorder
Trouble with camcorder
After 3 seconds of recording or playback I get the message "reinsert the cassette" and then in the top right corner the blinking message c:31:22. Also when rewinding or fast forward. After reinstalling the cassette it works again for a few seconds and then repeats the message. Thanks for your time mark
  • 883 Answers
Try cleaning the rubber pinch roller with a cotton swab dipped in alcohol
Posted on May 26, 2007
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
REINSERT CASSETTE MESSAGE ON Sony Handycam TRV138- Hi8
I bet it has been in a cupboard and not used for a long time. The camcorder has a "Mechacon Fault". Maybe electronic, (component failure) or electrical, (switches tarnished contacts).
Jul 14, 2017 | Sony CCD-TRV238 Camcorder
Flashing yellow arrow
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 10, 2007 | Sony Handycam DCR-TRV250E Digital...
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Cassette loading error 31:23
Nov 18, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Aug 07, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony CCD-TRV238 Camcorder Logo
188 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
