Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series vacuum on/off swicht not working
My rainbow was working just yesterday. Today the on/off does not respond for the main unit (the one conatining the motor and water basket), but I know that power is passong through since the vacuum arm starts running when I press the power botton
    Habit-Forming:
  • Rainbow Expert
  • 119 Answers
It is possible that the motor is throwing the circuit breaker. It is self resetting so your unit should turn back on after an hour. If it does not, please give us a call at 800-523-0510...www.rainvac.com
Service Specialist
Posted on Jan 17, 2013
  • Rainbow Master
  • 18,402 Answers
This video may help if you need to replace power cord or on/off switch
Posted on Oct 25, 2012
reddevil6
  • 1673 Answers
SOURCE: Rainbow E Series Suction Problem
Being an E series some have a corrgated filter in the top, there is also a filter on the back. Could be a motor problem, not turning as fast as it should, in which case you will have to replace the motor. You might check, some had a 10 year warranty on the motor. If you are the original owner and only have had it 5 years, then it may be covered.
Posted on Jan 19, 2008
RockyNR1
  • 324 Answers
SOURCE: aquamate II NOT WORKING !!
If this is pre-owned unit that you bought - it may be clogged. If people who had it did not rinse shampoo solution out of the system after using it - shampoo becomes thick and sticky when dry and may clog the tubes. Also it may impair the pump.
Pump may also be defective. It should make a humming noise while in operation. It is hard to hear when vacuum is on so take the Rainbow with water bowl of the white AQM basin, turn on the vacuum while AquaMate is still plugged in, put your hand on the black plastic on the white AquaMater water nontainer and you should feel pump vibrating inside.
If you feel it start with filling up the white tank and bottle with warm water, turn AQM on and try rinsing it. However if water can not get through at all - it will not help.
Then take the handle apart (a bit tricky but be careful ant to break the plastic and you will get it open). See if there are no clogs there. in tubes nor the VALVE.
If no clogs fing - you will have to acces the pomp and few short tubes inside this plastic box assembled onto the water tank. to get it open you may have to break off 4 latches that hold top halve to the bottom. You can purchase one HERE. Make sure that tubes inside are not bent at the sharp angle and obstructing the flow. If you need any tubing - you can find it cheap at Home Depot (have a sample with you so you pick the right diameter).
Clean all tues inside and you possibly will have to take the pump apart to get it cleaned. If it is not working you can buy one HERE.
Stil no luck - put EVERYTHING in a plastic bag or several bags and then in a box and ship it to us - we will get it running.
Good Luck,
Rocky
Posted on Mar 28, 2009
  • 11 Answers
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
Posted on Jul 03, 2009
  • 883 Answers
SOURCE: Rainbow E Series Vacuum
the motor is actually spinning backwards? try to confirm this.
Posted on Jun 02, 2007
C4RN1
  • 14 Answers
SOURCE: I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Posted on Jul 31, 2009
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
How to fix rainbow vacuum e series on/off switch
You can find a walkthrough on disassembling your E series one speed Rainbow here.Rainbow E Series Motor Unit if you go to step 9 that gets you to the switch and how to unwire it.
GoodVac.com
800-775-6586
May 28, 2014 | Rainbow 75th Anniversary Canister Vacuum
The rainbow sat for too long on the water now wont run
So depending on how long, you may have rusted out the bearings in your motor, especially if it sat so long as to eat the glue off of your gasket.
Sounds like you may need a new motor, gasket, baffle plate and separator.
Rainbow series vacuum main unit parts
GoodVac.com
800-775-6586
Apr 14, 2014 | Rainbow E series Canister Wet/Dry Vacuum
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Electric hose on rainbow not working
Be sure to have a solid connection and that you hear two clicks when connecting your electric hose to the front of the main unit. If this connection is not solid, then the receptacles can not make contact. Try bypassing the hose and plug your power nozzle directly into the front of the main unit to confirm that the hose is the issue.
RainVac
www.rainvac.com
800-523-0510
Aug 06, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I smelled something burning one day , but i kept using my d4c, now the motor part does not run but the top plug in will run
I work on Rainbows. D4C-E2 etc. Not sure what you mean by the top plug in. There are two motors in the rainbow, one in the main unit, one in the power head. Where was the odor coming from? email me back with more info, I can help you with this. Jerry
Nov 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Plugged vacuum in and no power
Hook up your power head and see if it works. If it does, most likely the problem is in your main unit motor resistor. If it doesn't, then check another outlet. Still no function, switch or loose connection inside.
Rainbow e series musty odor
The unit and the nozzle have to be taken apart and cleaned. You almost for sure will need a new HEPA and possibly even the motor cooling filter. There is a lot of dust inside that got moist (moisture in the air,vacuuming wet carpet, maybe you have pets or everything together)
It will require a bit more advanced skills but you do not have to be a vacuum repair professional to do this.
Sep 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
756 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
