Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Replace drive belt lt 1000
Lost manual need instructions and belt size
  • 430 Answers
Look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Posted on Oct 25, 2012
SOURCE: I need to replace the drive belt to the transmission
On the side of the deck there is a metal rod running along between the tires. Push it back then pull it forward when it releases from the catch it will move the pulley and release the belt. Hope you can figure it out I believe it is on the side with the brake pedal.
Posted on Apr 04, 2009
SOURCE: trans dose not work since i replaced rear tire on lt 1000 tractor
Similar thing happened to me . There is a half moon "key" that slides into a groove in the axle. Sounds like that fell out when you took off the wheel. Look around where you took the wheel off to see if you can find it. If not they're not very expensive at a repair shop. I did not know this & I took in in to the shop. Luckily they only charged me for the part.
Posted on May 18, 2009
  • 8 Answers
SOURCE: how to replace deck belt on lt 1000 craftsman
there are several belt guards that you will need to loosen then the belt will slip right on. having someone hold the clutch will make it easier, and the belt diagram should be on the deck. If not, these are common mowers, so a search for this or a friends/neighbors mower may hold the answer. Be sure to re tighten all guards or your belt will pop off and wear out very fast against these metal parts
Posted on Oct 16, 2009
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
  • 19 Answers
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
I need instruction for diy fixes for diamond 1000. I need to change the drive belt on my diamond laser 1000. I'm having trouble with access to the wheels. Sorry now I see this is a car site.Nevermind
The problem with a laser 1000 is the only thing replaceable is the drive belt and the blade. The rest of it was built to last the life of the saw.
Dec 26, 2016 | Cars & Trucks
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Belt replace instructions
changing the belt on a craftman lt 1000
Jan 07, 2014 | 1997 Jeep Wrangler
Could you provide me with a manual on Sears LT 1000 Riding Mower model # 917.271652?
Try online at "SearsParts" and type in your model number and you will see how to get the information you want. Be blessed.
Jun 19, 2013 | Garden
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Could you send me a diagram how the drive belt goes around the pullys thanks its a craftsman lt 1000 not sure of the year model
Hi and welcome to FixYa, I am Kelly.
Here is the diagram:
http://www.brandywineits.com/graphics/LT1000/PulleyConfig.jpg
One of the major problems on the LT 1000 is that the belt gets installed wrong side out. Just make sure the V of the belt rests in all of the mandrel and drive pulleys correctly.
Thanks for choosing FixYa,
Kelly
May 04, 2011 | Garden
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
314 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
