Question about Bosch Axxis WTL 5410 Electric Dryer
Dryer not heating
I purchased this apartment last year and the dryer had been working fine. It no longer warms up but will continue with the cycle spinning.
  • suzel May 03, 2009
    My Bosch Axxis WTL 5410 Condensation Dryer will not heat up either, even tho they are set on "Extra Dry".  Sometimes it makes a straining, squeaky noise as the drum spins around, and sometimes the light bounces over to "damp dry" for no reason at all.  Is this something I can fix by myself, or do I need a new part?  The dryer is only 4 years old.
    Sergeant:
  • 311 Answers
Make sure your on an heat setting.if your are next is to check power at the cord220 volts.if you have that.check your connections at the other end of the cord where it attaches to the dryer[they will burn there]if ok then need to check voltage at element.220 volts.God bless,tom
Posted on Jan 02, 2009
My dryer is slowly - over the course of about 2 years - taking longer and longer to dry my clothes. I usually have to run the clothes through 2 or 3 drying cycles to get them dry. What do you think is...
Usually this is caused by the heating element (s) going out.
Tear the dryer down to the elements and test for continuity through them. If one fails the continuity test, replace it.
Best regards, --W/D--
Jan 21, 2011 | Dryers
Why would my dryer not be heating?
Most likely the heating element. But look for blockages that could cause safety's to trip before purchasing expensive heating elements is what I always say. To prevent fires dryers have a series of limits wired into the harness to shut down the element in case the dryer over heats. Maytag blowers are made of plastic and often are a cause of overheating. The clothes take much longer to dry if a blower wheel is to blame, so check that too. themobilian_94.jpgthemobilian_95.jpgthemobilian_96.jpgthemobilian_97.jpgGive me your model number and I will be more specific. Not all maytags are the same.
Nov 10, 2010 | Maytag Dryers
GE DSXH43EAWW dryer stopped working mid cycle
unplug it,take it apart and check it out,you could have snapped the belt,there's a belt switch so if the belt breaks the dryer won't start,or if you haven't taken the dryer apart and cleaned it out and also the vent line you could have popped one of the t-stats,only way to tell is by checking them with a meter.the dyer should be cleaned out once a year ,if not the air can't move freely and one of the t-stats will pop as a safety,the dryer will run to hot and take out the thermal fuse or the high limit t-stat,if it's been taking longer to dry the clothes or if you see lint stuck to the bottom of the dryer door these are signs of bad air movement and the dryer and vent line needs to be cleaned out.
Dec 30, 2017 | GE DSXH43EAWW Electric Dryer
Dryer no longer heats. Checked continuity on the
check continuity of the thermal fuse,the cycling switch,the hi-limit switch any of these that are open will stop heating all are on or near the element or air flow path to the vent
Jan 27, 2010 | Kenmore 64902 Electric Dryer
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Dryer blowing cold
Check the following to address this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Please rate and have a great day:)
Jun 01, 2009 | Hoover Dryers
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Heat to start, then no heat..
replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
177 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
