Question about Air Tools & Compressors
How do i hook my 5hp compressor up direct
How do i bypass the pressure switch and hook it up direct.
  • Robert L Kershaw Oct 24, 2012
    What is the problem you are trying to solve?  Bypassing the pressure switch will cause the compressor to run continuously, which will burn up the compressor and/or motor.  Plus it is a safety hazard to run a pressure system beyond it's rated limits.  If the compressor and or tank does not have a pressure relief valve, some part of the system will burst.
    President:
  • 1,388 Answers
By direct, you most likely mean continuous run where the compressor runs to set pressure then a spill valve or unloader will discharge the rest of the air. This can be done with a pilot valve available thru WWW.Grainger.com or ebay. Make sure that the thread sizes will work on your compressor. You do not have to remove the pressure switch, however the unloader must unload before the pressure switch setting. For an idea on plumbing, take a look at gas powered compressors or an electric RolAir compressor that has that feature installed. Good luck.
Posted on Oct 25, 2012
mrhappyface
  • 205 Answers
SOURCE: Husky 17gal 5hp compressor will not cut off when
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Posted on Feb 26, 2009
  • 65 Answers
SOURCE: the pump builds up pressuer to 80 to100 psithe
hi your problem sounds like the non return valve is either missing or is passing back pressure
the nrv should be on the hose that supplies the tank
Posted on Mar 24, 2009
  • 54 Answers
SOURCE: A DIRECT DRIVE COMPRESSOR & THE PRESSURE SWITCH IS FAULTY
STOP! Your pressure switch is doing what it is supposed to, but the tank check valve is leaking. This valve is usually at the tank where the line from the compressor head enters the tank. The small tube line from the pressure switch probably also goes to this valve. You'll need to clean or replace it.
Posted on Nov 17, 2009
  • 36 Answers
SOURCE: I have a 5hp 16gal. 135 max psi. The compressor
take the power surply cover off and look down the side on the butten at the contacts, id say it isnot the pressur switch itself, and make sure all bolts are tight and check the reeds
Posted on Jul 30, 2010
aquaman987
  • 927 Answers
SOURCE: My compressor builds up to preset pressure just
This switch is only rated for up to 2 HP at 240 volts and 1-1/2 HP at 120 volts. Using 3 phase power, you can go only up to 3 HP. That would not cause the problem that you discuss, but it is an unsafe condition.
Some Square D switches have a small relief valve so that when the compressor reaches pressure, the motor stops and the relief opens and lets pressure out of the compressor cylinder. Does your switch have that and might that be what is "leaking"? I believe that if the compressor is tight that the leak would stop rather quickly.
Posted on Dec 11, 2010
Pressure asdjustment
open pressure switch an dunscrew main screw/nut inside tthis will reduce the tension on the spring inside and will cause it to cut out earlier
May 06, 2013 | Ingersoll Rand TS4N5 Ir Electric...
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
Locate pressure relief valve on c5160v1 eagle compressor
it is located on the 4 port manifold on the bottom of the pressure switch
Jul 05, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Need to wire my 5hp compressor to a 11hp 5500 watts generater
I'm not sure what you mean by "wire my 5hp compressor to a 11hp 5500 watts generator?" The compressor should have a three prong plug-in cord from the pressure regulator and the generator should have a three prong outlet to plug it into. Do not try to wire the compressor directly to the power generator (dynamo), the current must go through the circuit board then to the outlet to make sure your compressor motor is getting the proper current.
Feb 21, 2012 | Coleman Air Tools & Compressors
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have an old 5hp 20 gallon horizontal Craftsman air compressor that is well over 20 years old. The on off presure switch died so I replaced it with a Powermate unit of the same on - off pressure...
possibly an installation problem
most control units screw directly into the tank and the pressure is read directly to the diaphragm that controls the switching
check if the bleeder line is supposed to be attached to the control unit at all
unless you have a peculiar set up the compressor line goes to a nonreturn valve into the tank
there is a relief valve in the tank that blows off when dangerous pressures are reached ( around 120 psi)
there is a fitting where the control screws in and that reads tank pressure to control the on/off of the motor
Apr 17, 2017 | Craftsman Air Tools & Compressors
The pump builds up pressuer to 80 to100 psithe motor cant turn any more due the pressuer in the pump, can you tell me why this happens dayton compressor model 5Z592 5hp it had a 3phase motor when it was...
Mar 24, 2009 | Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air compressor w/5hp motor
Assuming that the motor is factory matched to pump, it should be powerful enough to turn the pump. Most problems with motors are related to pressure switch and/or capacitor. The pressure switch could have burned contacts causing low amps to reach the motor. The capacitor should test at least 90% of rated value printed on capacitor. Some volt meters have capacitor check setting. Also this motor at 5 hp must draw lots of amps. The outlet should be rated at least 20 amps and plug the compressor directly into oulet without an extension cord. \
Secondary problem is the in-tank check valve. The check valve should hold in tank pressure without leaking back to the head of the pump. If check valve leaks, replace it with any brand of same thread size. enjoy
Oct 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
113 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
