Question about Refrigerators
Blocked water line
Model GS5SHAXTOL01, the water line from the water valve to the icemaker is blocked, should I be able to blow through it?
    Scholar:
  • 86 Answers
Hi, Yeah you should be able to blow through the hose! There should be a restrictor fitted in the water valve not the hose! The hose should be disconnected from the ice maker to tho as there may also be a restrictor in that to!
Posted on Jan 02, 2009
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Replace ice maker still not making ice, it still dispenses water
Before suspecting the solenoid water valve, check the inlet tube, where the water enters the freezer. Sometimes this tube gets blocked with ice. From the back of the refrig, you can disconnect the water line where it goes into the back wall of the freezer and you should be able to blow air through it. (having the freezer door open while attempting this will prevent any back pressure build up) If you can not blow through it, it is plugged with ice. Melt the ice with a hair blower from the inside of the freezer. Ice blockage can result from water seepage past the water valve (generally requires replacement of the solenoid water valve) or the fill tube extention may be too long, resulting in the tube touching the end of the fill cup on the icemaker, which results in a build up of ice and blockage in the fill tube. (this only requires cutting the fill tube a bit shorter, so it does not touch the end of the icemaker's fill cup)
If you were able to blow through the tube, you have either a bad solenoid water valve, or the icemaker is not giving it power (generally only 6 seconds of power near the end of the cycle) which would mean a new icemaker, as replacement icemaker parts are not available.
Jun 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Icemaker not making ice
Hi reach up and feel inside the ice tray where the ice is made. If you feel some ice then the ice maker is bad and should be replaced. If you feel in the tray and it is empty then either the water line is blocked or the valve is bad.
The way to determine which is to pull the unit out and remove the lower panel at the back. Trace the water line for the ice maker to the valve, remove the water line from the valve and blow through it. If you are able to blow through the line the valve is bad, if not able to blow through the line there is a blockage. Trace the blockage in the waterline from the valve up to the ice maker and thaw the ice blockage with a hairdryer.
If you have any other questions please feel free to ask. Mike
Mar 25, 2010 | KitchenAid Refrigerators
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker does not fill with water
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water valve ( the piece the wall water line connects to ) . If it doesn't dump after freezing , replace the icemaker . Also check the tube inside which delivers water into the icemaker to be sure it isn't blocked with ice . If it is , replace the water valve . Make sure the coils below fridge are clean of dust , lint , pet hair , etc..as this will slow ice production .
Aug 21, 2009 | Kenmore Refrigerators
I recently moved my Maytag refrigerator model MSD2554F from on part of the kitchen to another. It took me several days before I hooked the icemaker back up. I also replaced the water supply line for the...
Hi, Remove the line to the icemaker from the inlet vavle and blow through it. You can tell if it is blocked or not.
It might have frozen in the inlet tube through the wall of the freezer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Freezers
Icemaker no water going into icemaker
water valve is turned off, or waterline is blocked unit may have a screen or filter which can become blocked. remove waterline where it connects to unit,turn on water to check water flow at this point.no water, check line backward from this point to find pressure loss.if pressure is at unit connection procede checking forward for restriction . test machine.
May 14, 2009 | Whirlpool Refrigerators
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Will not make ice but will give water model number is gss22wgmb ww
check the dual water valve one side is for the icemaker the other for the water in the door
either a water valve issue or a ice maker problem
if the valve checks good check the line off of the valve to the ice maker you should be able to blow thorugh the line to the ice maker if you caint blow through the line it is frozen in the freezer behind the icemaker and will need to be thawed
if you can blow though the line to the icemaker
May 09, 2008 | Refrigerators
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
