I have a Lanier LW324, im getting streaks on my paper
I have ink streaks on my copies, how do i get rid of them?
jimnfl
  • 17 Answers
SOURCE: Streaks on paper
Nisha... If you haven't done so already, you need to run a few copies off the glass as opposed to through the feeder to determine "where" your problem is. Do the copies of your originals placed on the glass have the same line/streak defects as the ones made run through the feeder? IF NOT, then you probably have some sort of dirt or contamination on the FAR RIGHT side of the glass (ink, white-out, dirt, etc), and the machine is reading that as part of the image and printing it as a line. When running copies through the feeder, the scanner moves to the far right and parks there. Then the feeder moves the original over the scanner on the right side of the glass (the scanner stays still). So if you find the lines evident when using the feeder, but not there when copying off the glass, you need to clean the glass on the far right. IF YES (lines/streaks through the feeder AND off the glass), then your problem is most likely internal of the machine (bad drum in the L50 cartridge, dirty optical scanner, worn fuser rollers, etc) and I hate to say it, but will probably require a service call to rectify it. Sometimes you can actually take the L50 cartridge out immediately after running a few copies, and while holding it up, manually open the spring-loaded drum shutter on the under-side of the cartridge to expose the drum and visually inspect it to see if the line defects on your copies are evident on the drum itself. If so, you will most likely need to simply replace your cartridge and hopefully save a service call. If you can't really tell if the streaks are on the drum itself, then you're back to probably needing a service call. NOTE: DO NOT TOUCH, WIPE, CLEAN, OR OTHERWISE CONTAMINATE THE DRUM WHILE YOU ARE DOING THIS, and do not leave the unit exposed to light for longer than a minute or so, because if the problem isn't evident/obvious with the drum cartridge, you don't want to risk damaging/contaminating it and thereby causing one. Please let me know if any of this was helpful. Thanks.
Posted on Oct 03, 2007
SOURCE: black streaks all over copy
Copies come out with one black line
Posted on Feb 05, 2009
SOURCE: I have a lanier 6713 that streaks and makes dirty
Cleaned the optics yet?
Are the drum and blade ok?
Maybe Fuser?
Posted on Feb 27, 2009
SOURCE: black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Posted on Mar 11, 2009
EmmettPinger
  • 63 Answers
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Posted on May 01, 2009
How do i get rid of streaks on copy. There are 3 black streaks on each copy. I have a xerox 420dc
Print heads need deep cleaning. If not ink jet, then the drum is damaged (scratched) and needs to be replaced to eliminate the bogus lines.
Jan 17, 2017 | Xerox Document Centre 420 DC Laser Printer
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
I am getting streaks on my copies using Canon IR 2200 - Pls tell me what to do to get rid of them
do some internal prints... and see if you get streaks.. if not then open the top and clean the glass table and the rectangular glass ****... look for black marks on the table and the **** and on the plastic where the paper feeds through to get to the ****...
Dec 15, 2009 | Canon imageRUNNER 2200
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Streak down the middle of each scan
Make sure the scanner glass is clean and there are no foreign objects.
If the streak is a white line then it could be a ink cartridge problem.
Jun 23, 2009 | Panasonic KV-S2026C Pass-Through Scanner
Lanier LW324 waste toner bottle full
Apr 20, 2009 | Lanier Office Equipment & Supplies
Lanier 6720
If when you open the rt. door are the streaks on the drum unit? If not remove the 1 screw and slide the fuser out and check there
-Carl
Sep 03, 2008 | Lanier 5235 Printer
Horizontal ink smuges
You probably have a buildup of partially dried ink on the carriage itself. I don't know how difficult it is to access the carriage on your machine but if you can force-feed several sheets of paper under the carriage and put a broad streak of alcohol across the sheets, you may be able to 'wipe' the ink buildup off of the carriage without disassembling the machine.
Mar 11, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
Nov 03, 2007 | Lanier 1205 Copier
52 people viewed this question
jasbo
jasbo
