Question about Philips Magnavox 27MS343S 27" TV
Thin white line
TV was working well in past. I turned it on one day to find a thin line across the center of the screen. The sound is also silent. This is a magnavox model # RS2745 C104 with SR 14939276 and Chassie # 27S101-00DD
    Habit-Forming:
  • 166 Answers
I think you have a power supply problem and that one of the supply lines is down it will need a technician to solve this problem.
SUPER8
Posted on Jan 03, 2009
  • matt martin
    matt martin Feb 14, 2011
    You have bad grounds on the vertical IC. If you know of a electronic hobbiest , they can repair this. The pins of the vertical IC have separated from the TV board itself. Resolder these pins and do not short the pins together with excess solder. The sound may return. But there is other things to consider. This TV by now has many many bad solder grounds through out the board. Close visual inspection will find areas that need resoldered. Have all the capacitors checked with an ESR meter and replace as necessary. We are looking for about two caps near the vertical IC and three in the horizontal section. Please replace the 200 volt 100 Mf cap and the deflection cap near the edge of the board. This cap is a 160 volt or 200 volt cap at 1 Mf. There is another one of the same value near and be hind the flyback transformer, also 160 or 200 volts at 1 Mf.Good luck. Hope the sound returns and a full picture on the TV as well. Show a few hands of support!
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Thin black horizontal line across the middle of the screen
It looks like you've got problems with your screen. If that one is on a warranty, replace it
Jan 22, 2018 | Westinghouse W32701 27 in. LCD HDTV
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Philips Magnavox 27MS343S 27" TV Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
