Question about Canon PIXMA MP210 Photo All-In-One Printer
When i set up the driver ,the scanner doesnt work
There is no icone shows up after the setting up of the driver to operate the sacnning process
  • Canon Master
  • 709 Answers
The driver is just a driver, you need to install the MP Navigator software. Canon classified it as a utility so look for it under Canon Utilities in your All Programs. If you cannot find it on the computer, install it from the CD or just do search for Canon MP Navigator and download it.
Posted on Jan 02, 2009
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
Scanner not working
There is not a driver available for Windows 7. One thing you can try is to run the software in windows XP compatibility mode if your version of Windows has it. When you go to run the software disc for the scanner goto my computer and right-click on the icon then click properties. You can then set the compatibility mode to run on XP. Then run the software by double left click on the icon after you have set the compatibilty mode for XP. I cannot guarantee this will work but it is worth a try. If you download the software to the desktop the process is the same.
Dec 24, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Mac boots to destop but no icons show. TRIED
have you tried putting the mouse icon to the bottom of the screen? that is a setting on macs it takes a few seconds to show the icons. if that doesnt work try going into settings and putting it back to default or factory reset of settings.
Sep 15, 2009 | Apple iBook G4 Mac Notebook
HP 6110 All In One Scanner & Printer
i dont have the scanner icon for HP. I loaded the drivers, but the scanner doesnt show up on the control panel.
How do I set up the scanner?
Aug 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Escndv.exe problem connected with Epson scanner 4490 Photo
http://www.howtomendit.com/answers.php?id=64090
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
May 30, 2009 | Epson Perfection 4490 Photo Scanner...
My pc doesnt recognise the scanner
OK.
The first thing I would try a different cable between the PC and scanner just in case it's faulty. Use a 6-foot USB) cable.
If this doesn't fix the problem:
Disconnect the scanner.
Remove the scanner driver so that we can start from scratch.
Go to http://www.mustek.com/mustek/supportdrivers.php and select your scanner model.
Download the twain driver and panel zip file.
Extract the file and install the driver
After installation, restart your system.
Once the system has restarted, reconnect the scanner.
Check the scanner icon on the control panel to make sure that it has installed successfully and that the red X is not shown.
If this does not work let me know.
May 18, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
Canon PIXMA MP210 Photo All-In-One Printer Logo
94 people viewed this question
old marine
old marine
Corne Viljoen
