Question about Alcatel Newbridge MainStreet 3600 Multiplexer
Pineado cable de consola 3600 newbridge - Alcatel Newbridge MainStreet 3600 Multiplexer
5 Suggested Answers
SOURCE: Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Posted on May 23, 2007
BAD421
SOURCE: NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Posted on Aug 02, 2008
  • 20 Answers
SOURCE: I dont have a problem.
Hi Berido, you can extend telephone lines over the 3600 by using LGE and LGS cards fitted with a ringer PSU in the 3600 at the end point, works well, for more info send me a mail, lenconradie@yahoo.com
Posted on Nov 18, 2011
  • 20 Answers
SOURCE: Where can I buy second
HI Basil, you can get the equipment from PC.
What's your problem?i am facing oblem power alarm and i can not get dial ton on my newbridge 3600 can any body help me to resolve this problem how can i check that
Is this connection between a LGS and LGE card?? if so then the only problem can be on the configuration on the two cards, both needs to be configured for "RE" remote extention.
Regards
Len
Jun 23, 2012 | Alcatel Newbridge MainStreet 3600...
I dont have a problem. I just wanna know how Newbridge 3600 series multiplexer help me extend telephone lines to a remote areas like Oil & Gas Pump Stations. I have STM 64 mux used as a backbone. So...
Sep 08, 2011 | Alcatel Newbridge MainStreet 3600...
Tengo una pantalla de 37 de tft samsung a la que conecto la ps3 por hdmi hasta hora sim problemas hoy la he conectado y me sale modo no compatible que es lo que puede pasar,e probado la ps3 en otra...
Puede ser que se haya desconfigurado el ps3, en caso de que sea este el problema, no desesperes que la soluci?n es muy f?cil. Conecta tu ps3 a tu tv a trav?s del cable hdmi, ahora, cuando enciendas la consola, deja oprimido el bot?n de encendido por unos 5 segundos, esto resetear? la configuraci?n de video de la consola y esta se ajustar? autom?ticamente a tu tv, presiona (X) cuando la interface te lo indique. Si esto no lo soluciona, y la consola funciona en otros tvs, es otra la situaci?n y es probable que tu tv este fallando.
May 05, 2011 | Sony Playstation 3 (PS3) Console
Como se pone el internet en el wii
Para conectar el internet a tu consola de Nintendo Wii te recomiendo ver el siguiente arcitulo publicado por Nintendo.com:
Para conectarte via WIFI
C?mo conectar tu consola Wii al Internet
Para conectarte con un cable ethernet
Wii - C?mo conectarse al internet
Si luego de seguir paso a paso esa guia sigues teniendo problemas de conectividad con tu consola verifica que tengas acceso a internet desde computadora para descartar problemas con tu proveedor de internet, tu modem o tu router.
De necesitar alguna sugerencia adicional puedes publicar mas detalles del "setup" que tienes en tu network para hacer un troubleshooting mas espec?fico.
Mar 05, 2011 | Epson Stylus Photo R300 InkJet Printer
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
Can u tell me function of DSP , LGS CARDS IN 3600
LGS is same with FXS (Foreign eXchange Subscriber) card. It's voice card for serving voice needs with 2 wire connection. A analog phone connect to LGE on alcatel 3600 and other analog phone or PBX on remote alcatel 3600.
Look the others card e.g LGE (FXO) and E&M card.
DSP card processed the voice.
thanks
Feb 26, 2009 | Alcatel Newbridge MainStreet 3600...
Can't access to alcatel 3600 node managment station from faceplat
SP1 is belong to VT100
VT100 RJ45 DB9 1 8 2 7 3 2 4 3 5 5 6 4 7 6 8 --
Jan 09, 2009 | Alcatel Newbridge MainStreet 3600...
Hello
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
42 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
