Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
X box 360 wireless adapter
Just bought a xbox 360 and need a wireles adapter to do the live 360 thing. .I have a home network wireless and use the netgear versoin of USB type adapter. can I buy this one and save $$ will it work or just break down and buy MS $100 version?
    Problem Solver:
  • 4 Answers
Go to amazon.com look at theyre adapters for the xbox they say it works for $45.00
Posted on Jan 06, 2009
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
How to get your wireles internet to work no the xbox360
2 things you need a wireless adapter for the back of the box and then go to settings on the box and network then you can choose wireless there
Oct 26, 2010 | Microsoft Xbox 360 Console
Are all xbox 360's able to connect to wireless broadband
Yes, with the wireless adapter, and wireless router, any Xbox 360 can go wireless.
Go to "My Xbox" -> "Network Settings" -> "Configure Network", the Xbox will ask you a few things about your network, and that's it. You should be connected pretty easily.
Mar 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 adapter
you will need to go ito your modem/routers settinngs oen internet browser type 192.168.1.254 then go to wireless then custom services open the box then scroll down to the bottom and select box live the another screen comes up with a box in it open it an select the bottom one it will be your xbox
Dec 27, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live
Just give me the make and the model no. I'll give you the user manual..
May 04, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live wireless connection
It only works with the microsoft adapter nothing else. You'll have to buy the Xbox 360 Wireless Network Adapter from microsoft and it cost around $100 bucks. It suxks that microsoft charge for this thing, it should come free with the machine
Oct 03, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
285 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
