I have a problem of setting up DNS on my Belkin 7230-4 wireless g router , I have upgraded to the recent firmware yet it wouldn't pick up the DNS
  • 2,878 Answers
You don't setup. It is the same as the DHCP server on the router (ipconfig /all).
Normally you really don't use DNS at home. It is for resolving an IP to a name (like on the web). Belkin web interface also shows the ISP WAN DNS server, but again not really used. Even if you have a multi-pc network, the name is handled by DHCP and Windows.
Feel free to post back if I misunderstood the need or problem.
Posted on Oct 25, 2012
evelasco
  • 52 Answers
SOURCE: Belkin FSd 7230-4 router security
1. Open your net connexions
2. At your left side menu, find create a new connexion.
3. Answer all the question.
4.Went finish you have create a new connexion.
Posted on Oct 06, 2008
SOURCE: Belkin Router doesn't connect to internet
GUYS, omg this is so damn unbelievable. I've searched EVERYWHERE on the internet until some genius told me that the reason why I couldn't get internet even though I connected to the router was because of the stupid Norton Internet Security Firewall that was still in use after uninstalling. After I downloaded Norton Removal Tool, EVERYTHING was back to normal. I'm NEVER going to use Norton again, I don't care how much they have improved I was using 2008 and it caused me so much trouble. I recommend everyone out there to not use Norton as well. People out there are saying that Norton is a virus itself in that it is VERY hard to uninstall.
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: problems with my Belkin N1 router since we have 1 PC on Vista
to solve this problem you need to set up static IPs on your LAN clients. Whether your SIP provides you with a static IP or not makes no diffrence you can still assign one to each machine on your network and that should solve the problem.
Posted on Aug 02, 2009
  • 1015 Answers
SOURCE: belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Posted on Sep 08, 2009
  • 700 Answers
SOURCE: my belkin router won't connect to my computer
Just sharing this;
Hook the internet connection again on the computer directly to its LAN port like the way it is first connected. Then activated the net connection, double the double monitor icon on the right side, bottom side of your monitor. Then click status, support, details you will see the net details of your net.
Then reconnect the system back where the router is connected on the system, then use your the DNS settings manually on the router. By getting to web page utility setup of the router.
Hope this helps.
Posted on Sep 28, 2009
Belkin Wireless router driver for Ubuntu
No drivers are required since routers are not installed but are administered. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
HTML Browser based User Interface (http://192.168.2.1) Default is no user. No password. Hold the reset till it cycles in the back to clear any custom settings. From here use the firmware update, but make a backup before actual update.
Oct 24, 2012 | Belkin F5D8236-4 N WIRELESS ROUTER4PORT...
Every time i am on PSN i get logged off for some reason it says DNS Error
1. If this is a DNS error there main be an issue with the server you are connecting to .
2. you possibly need to do a firmware update on the router.
3. the tcp/ip settings in the Windows> you have them set to obtain an IP automatically.
4. check your wireless settings and DNS setting in the router also to automatically detect DNS.
5.Check the "whois" on the INTERNET at Domain tools and check the IP and see where it authenticates. example if it's an IP of 207.203.11.3 type that in the required field this will tell if the DNS server is working . If it is then it is your device and the router.
Sep 13, 2011 | Belkin Computers & Internet
I can't connect to internet through wifi with belkin 54g but netgear works fine, it can't assign an ip address and i have it set to automatic configuration.
You can try to change channel on the router
Connect Belkin router with a Cable to the computer Open router router interface with its IP address Goto wireless settings and change Channel to 6 / 11 and apply settings You can also try to disable Wireless security to check if it connect without security Check for the latest firmware for your router and upgrade it.
Hope this help, Or you can ask for help
Jul 13, 2011 | Computers & Internet
Problem with wireless internet connection. Belkin. It only connects for 2mn and then dies...
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Apr 06, 2010 | Belkin (F5D7231-4) Wireless Router
I have a belkin router, the wireless part of router isn't glowing. why?
You will need to check the wireless settings of the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Make sure that the wireless SSID broadcast is enabled.
If that is enabled then I believe you will need to upgrade the firmware of the router.
After upgrading the firmware of the router, you will need to reset and reconfigure the router.
Click here for step by step instructions
Jan 31, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
Jan 14, 2010 | Belkin Computers & Internet
I'm trying to upgrade the firmware on a belkin wireless router
upgrade of Firmware is at your risk...
never upgrade Firmwares....they are not ment for that....
your hardware may be rendered useless after firmware upgrades....the chip inside your hardware is programed to run based on a certian program installed as a firmware from the factory....sometimes upgrades will screwup your hardware....so be careful and do it at your own risk...
Dec 10, 2009 | Belkin (F5D7230-4) Router (587009)
Laptop won't connect to new Belkin G Wireless Router
Just Install the hardware and insert the driver of the router...then follow the instruction...
May 10, 2009 | Belkin (F5D72304F5D7000) Router
Belkin can't work it out!
If u r wi-fi router uses encryption u have to put it in u r connection wizard and trying putting DNS servers of u r service providers.
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
David Payne
David Payne
