Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Dishwasher stopped and will not start
I have a Whirlpool Gold dishwasher GU2500XTPT3. It was in the final cycle and quit working. Left some water in bottom of unit. Touch-pad buttons do not work. No lights either. I checked the breaker and power to the unit & it has power. There is power to the control board in the door. The latch seems to work. What to do next?
  • Anonymous Mar 15, 2009
    What does the fuse look like?
  • Anonymous May 16, 2009
    I have the same problem. dishwasher stopped in final cycle,left water in bottom,will not run,lights on panel will not work. I checked breaker.I also have a Whirlpool.
  • 38 Answers
Try jigling the ribbon cable that is connected to the control panel. These ribbon cables sometimes fail. Also check the fuse on the control board to see if it is blown.
Posted on Feb 23, 2009
Turned on the 1 hr button and it did start but after a few minutes it stopped. None of the controls are lit and the water is just standing in the bottom. What do I do to get it started again?
If it fills with cold water, it will pause and try to heat the water... if there is no heater function, it will never achieve wash temperature.
To invoke the Diagnostics Cycle, perform the following while in standby:
? Press any 3 keys in the sequence 1-2-3-1-2-3-1-2-3 with no more than 1 second between key presses.
? The Service Diagnostics Cycle will start when the door is closed Whirlpool Dishwasher High Limit Thermostat WP661566 , Whirlpool Dishwasher Heating Element W10518394 , Whirlpool Dishwasher Control Board W10751502
Jul 12, 2016 | Whirlpool Dishwashers
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
Why does it run part of a cycle then stops?
Sounds like filter needs cleaning out if blocked this will stop the machine working
Mar 10, 2013 | Whirlpool WDF750SAYM Gold Dishwasher
5 year old dishwasher.Press START button,dishwashing cycle kicks in for a few seconds then stops.A few seconds wait and it starts again, and on and on.It finally works its way to the full cycle.
The dishwasher is taking too long to fill with water...
Here is a tip that will help you to find out whywater will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 24, 2011 | Whirlpool Dishwashers
Dishes have a film and residue left on them after they are washed
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Nov 27, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
After dishwasher completes cycle, it starts again. It will keep going unless we stop it.
If the cycle does not stop that is usually because of a faulty water level sensor. The floater that controls the water level in your appliance.The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely. Check if sensor is stuck or if switch is faulty.Some machine may use a membrane switch instead of a floater.
Mar 27, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
464 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
