Question about Acer Aspire 5336-2283 Notebook
Acer Aspire 5336 boot/screen/ram problem
Hi I got a problem with my laptop. When pressed power on the light on the button comes up and you can hear fans and hard drive working for couple of seconds and that's it - after a short time everything dies. The screen stays black all the time. It happened before and I swapped RAM memory into different slot as that was the solution I found somewhere - it seemed tobe working but after couple of weeks it happened again and is not working since. Any help would be muchly appreciated.
  • 41 Answers
Yeah, sounds like a ram problem. You can try re-seating it by pulling it out and putting it back in or its very possible the ram has gone bad and you will need to replace it.
Posted on Oct 24, 2012
4 Suggested Answers
  • 121 Answers
SOURCE: Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Posted on Jun 17, 2007
  • 18 Answers
SOURCE: help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Posted on Nov 19, 2009
  • 639 Answers
SOURCE: acer aspire laptop start button is on but laptop
Have you try to re-install your Windows, use CD driver to install it and let it boot from CD.
Posted on Feb 16, 2011
Acer Aspire 5542 wont startup
Bring it to a repair shop and have them check it out. They should at the very least be able to recover you data.
Jun 29, 2012 | Acer aspire 5542 1615
LAPTOP ACER 4520 NOT CONTINUE BOOT UP NO IMAGE ON SCREEN BUT HAVE LIGHT ON POWER BUTTON
your ram could be bad, your screen could be dead, or you have bigger problem with *********** board. When you press the power button, do you hear the hard-drive start?
Jul 16, 2011 | Acer Aspire 4520-5141 Notebook
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Power light comes on but computer does not boot. Screen is blank, can hear hard drive but no lights show. Happened after power cut
READ carefully before doing...
You can take to some shop and tell the shopkeeper to check RAM chip.
Else you can do your own...open the back cover remove the RAM then press the power button without inserting the RAM.
Once it makes some sound shut down the system again and put the RAM back into the machine ( make sure you inserted chip in same direction as you removed.)
Jul 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Booting
Press the FN F5 screen to see if you can toggle the screen on. If you have a external monitor plug it in to the notebook and see if you have video. If it show in the external monitor your LCD screen has gone out.
I hope this helps.
Feb 19, 2009 | Acer Aspire One PC Notebook
Acer aspire 4710
If you have getting dull display it's a inverter problem in laptop.or if you not getting no display(screen) then two types of problem in your laptop please try to solve that problems.
  1. Please check RAM is working or not.
  2. If RAM is good then it's a Mother Board Problem.
Thanks
Rammohan
Oct 06, 2008 | Acer Aspire 5610-4648 Notebook
Laptop Wont Boot
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5336-2283 Notebook Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
