Question about Kenmore Kitchen Ranges
Model c970 635131 need to reset
Oven not working but top burners are working
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
  • 338 Answers
SOURCE: Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Posted on Nov 30, 2008
SOURCE: Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
Oven has power but none of the burners on top or the bake or broil elements work
Go to breaker panel,turn off and wait a minute and turn on,may reset it.
Oct 28, 2012 | Kenmore Kitchen Ranges
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Front right burner on GE glass top range not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
Model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Nov 12, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchen Ranges Logo
269 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
