Question about Panasonic Palmcorder PV-D209 Camcorder
Screen display on "PC ACCESSING" on my Panasonic NV-GS15 digital video camera
I bought this digital video camera couple of years ago and I didn't use it for last one year. Now when I switched it on, it only display "PC ACCESSING" and a white memory card sign below it with "PC" written in black in it in the middle. It does not do anything else. Even if change the mode to video camera, still camera, video playback, picture viewing or PC mode, it only displays what I descibed above. Battery is charged full and I cannot see any other obvious defects.
SOURCE:
sainisonu
  • 156 Answers
SOURCE: Panasonic NV-GS15 Mini DV Digital
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
Posted on Oct 23, 2007
  • 5 Answers
SOURCE: Playback problem on Panasonic NV-GS15
It is probably a dirty head. One camera i had i had to clean it much more often that i wanted to and certainly before any important shoot.
Here is a tip though. Always use the same make of tape (and code). If you do change your tape (or code) then clean the heads before you put in the different tape. this is all to do with "dry or wet" lubrication used on different tapes. i do not know enough about that to comment, but the tip comes form a very good source.
Some people run the whole tape through on record (with the lens hood on) before they use it. I do not think it will help for this problem, but you can try.
Posted on Jan 01, 2008
SOURCE: Service manual for Panasonic Handycam NV GS15
I fixed 2 cameras with same problem "Push Reset Switch"
Removed small foreign plastic object which was jamming mechanism without stripping.
In both cases a very tiny piece of one of the broken plastic 'catch' of the door was the problem.
Turn unit upside down and give it a good shake-up and it will drop off & problem solved.
Hope this helps.
Seedata
Posted on Feb 07, 2008
  • 7 Answers
SOURCE: How to get my PC recognize the Panasonic NV-GS15
Solution A: make sure you are using the correct cable for what you are doing (eg USB for webcam and importing photos and Firewire for transferring video footage
most desktops have firewire plug in them but laptops don't usually
to get a firewire plug in a laptop you need a PCMCIA to Firewire Cardbus (ask your local retail store for one or buy one on ebay etc.)
after that put the cardbus in your PCMCIA slot and restart
then go to Windows Movie Maker and press "capture from video device"
hope this helps!
James
Posted on Feb 21, 2008
SOURCE: Push the reset button,PANASONIC NV-GS11
TURN DIAL TO PLAY---TURN ON ---TURN OFFF
TURN DIAL TO RECORD----TURN ON
You will see which position works....
Posted on Jul 18, 2008
Hi! Panasonic Digital Camera would be my need NV-GS15 his software Windows the 7. -hez. Please writes it from where I would be able to download it. Best regards:
May 07, 2011 | Panasonic NV-GS150 Mini DV Digital...
How do you put movies onto a PC
Please, I have a kind of digital Kamra PANASONICE NV-GS15 I want a program to read on your computer
Oct 03, 2010 | Panasonic NV-GS15 Mini DV Digital...
Downloading the video from panasonic NV-GS15 to PC
I want to Downloading the video from panasonic NV-GS15 to PC
Jun 19, 2009 | Panasonic NV-GS15 Mini DV Digital...
THE USER MANUAL OF NV GS15
Click Panasonic Support and check bottom of page to download user manual of NV-GS15 camcorder.
Apr 02, 2009 | Panasonic NV-GS150 Mini DV Digital...
WONT TRANSFER TO PC
You need a software program to do it with. Pinnacle Systems Studio software will work. Once the camera is connected to your pc and turned on a screen will appear asking you to use the program.
Jul 26, 2008 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital How to capture recorded vedio from Panasonic NV-GS15 Mini DV Digital to Laptop. I have Windows Vista and firewire port.I try to connect it with 4 pin but Movie maker...
Oct 22, 2007 | Panasonic NV-GS15 Mini DV Digital...
Oct 20, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic Palmcorder PV-D209 Camcorder Logo
116 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
