Question about Garden
Hello I have an echo pb-500T, my cord won't pull.
  • 430 Answers
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Posted on Oct 25, 2012
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
EarthJam
  • 23 Answers
SOURCE: ECHO blower won't pull
I think i know how to fix it.. :)
Its got a compression lock. take off the spark plug and pull the rope.
Dont forget to rate me back please! -Jeff -Anchorage Small Engine.
Posted on Feb 04, 2009
  • 133 Answers
SOURCE: pull cord came undone
sounds like the spring might have broken. Sometimes they are a pain to rewind. Might want to see about a new pull assembly. But first take off the shroud to see if the little pieces of metal or plastic that engages the assembly on top of the fly wheel are ok. If so untie the cord to the hand hold and remove rope from the pulley inside. Then turn the pulley a couple of times and let it go(but watch your fingers). If it spins pretty fast then turn it again till you get some tension and I put a screwdriver through the fins so it doesn't unwind (but line up the hole where the line goes through first) then put the line through the holes and tie a knot. Then pull out the screwdriver and slowly let the line rewind. If it rewinds reassemble and it should work fine for you.
Let me know if this helped.
Thanks
roundo4
Posted on Aug 02, 2009
  • 122 Answers
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
Posted on Feb 26, 2011
  • 37 Answers
SOURCE: I have an echo pb
I would first check the fuel lines running to the primer and then the bulb for a hole I would also do a carb kit
Posted on Jun 15, 2011
Why does my blower floor out to kiwk
adjust need and seat or make sure needld a seat or seated right soundes like not should be no need to adjust needel sounds like put in wrong flip it over metal side go on needle
Aug 06, 2014 | Echo Power Blower PB-500T
Like the motor is locked up
pull muffler off look at piston if all scard up its bad by a new one and add more oil to your gas you ran to hot only fix but new one
Aug 05, 2014 | Echo PB-500T GAS-POWERED BACKPACK LAWN...
Throttle handle trigger is stuck
see if the linkage on the carburetor is stuck
Nov 18, 2013 | Echo Backpack Blower PB-500T
Replace pull cord
Echo is one of the easiest pull cords to fix, remove the screws on the rewind and take off the motor and flip it over and pull old rope out and put new rope in wind the spring the correct way so when you pull rope it tightens spring so it will wind back up when let go, not winding too tight !
May 22, 2013 | Echo Pb - 413t Backpack Blower
How do I remove a flywheel from an echo pb-413t? I bought a flywheel puller but it still won't budge?
It was pretty hard to get a flywheel puller on there wasnt it?
Use a brass hammer and a large flathead screwdriver. being carefull not to pry on anything but the crankcase and flywheel insert the screwdriver under the flywheel. With the hammer tap on the short cooling fins (These are tougher than the longer ones- you dont want to break off any fins) while prying up on the flywheel with the screwdriver. A few taps and it should pop loose. It doesnt require a lot of force but you need to be decisive with your blows.
Oct 04, 2012 | Echo Pb - 413t Backpack Blower
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
Dec 10, 2010 | Echo Garden
Feb 03, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
1,323 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
