Frigidaire Affinity front loader washing machine
    Problem Solver:
  • 4 Answers
Try putting it on a stand, (most come with them) I think that the drain hose needs to be higher than the drain tube in your plumbing for it to fully drain.
Posted on Oct 24, 2012
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
SOURCE: My Frigidaire Affinity front loader smells like mold
Ours gets a musty smell because water gets trapped in the air-tight drum. I leave the door open in order to let the water evaporate. Also, the owners manual tells you to remove and clean out the soap dispenser drawer and the area that the drawer fits into. We have to do this monthly, as both get coated with black mold.
Posted on Jul 08, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
SOURCE: frigidaire affinity washing machine pause error
Because our machine was new and covered under warranty, we had a maintenance person come out three times for this issue, but the only solution he could provide was to use less soap. Apparently, too much soap disrupts a sensor. So, if you let the machine run without adding any more soap, it will (theoretically) fix the problem. And this solution did work, to a certain extent.
Even though I started using much less soap, the problem is still persisting. For awhile, I was successfully able to fix it by running a few cycles without soap. Now, however, it just won’t work. Maybe others will have more success with this solution than we did.
At this point, the washer is no longer cover under warranty and our best solution is to buy anything but a Frigidaire or related Electrolux product.
Posted on Aug 21, 2010
Reset error code 90on an fridgidare affinity front load washing machine
Most front loaders have door latch problems, try to deactivate the latch.
Jul 12, 2015 | Frigidaire Washing Machines
How to clean drain hose to frigidaire affinity front loader
One of the best ways to clean the drain hoze of a washing machine is to spool up the hose and place it into a bucket with at least 2 cups of vinegar (white or cider) and enough water to cover the disconnecfed hose. Soak overnight and rinse well before reinstalling.
Jul 18, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Front Loader Washer
Check if there is any gap or if the bearing are worn on the agitator, check by pushing the agitator for any play. If so the bearings must be replaced,
Sep 26, 2012 | Frigidaire Affinity FAFW3511KW 3.5 Cu. Ft....
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Loc message
Hi, It seems that you have accidentally locked the machine. Hold the "Options" button and the "Select" button simultaneously for 10-15 seconds and your problem will get fixed for sure.
Apr 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
