Question about Gateway MT3705 Notebook
Vista home premium wmp 11 decides to stop burning audio and audio
Had it fixed with registry mechanic, and two days later, frustrated again. there are NO viruses, no ADWARE, registry optimized, on line with Microsoft for three days, and they could not fix, I fixed after I gave up on them. other than this the system runs fine. I am at a loss.
  • tom_horn Jan 02, 2009
    You cannot uninstall wmp11 from vista, unless you know something Microsoft third tier support doesn't - which is ENTIRELY possible. Everything I see out here is a registry issue.
Uninstall it and reinstall if you have not yet.if it still happens google InfraRecorder and down load it it is free and it works well. now if you still have a problem then it has to be your rewriter check your driver it working and the firmware is upto date. If it is all ok then you will have to replace your rewrite.andy
Posted on Jan 02, 2009
  • magoo_andy Jan 04, 2009
    Hi sorry my fault was thinking of xp.your rite microsoft in thier wisdom decided to integrate it into the vista os so us mere mortals could not uninstall it.the problem can occur in several ways incopatable software ie:nero or roxi or if you have uninstalled something and it has been sharing the same drivers. The thing is, do you need wm 11 as your primary ripper & burner?. There are much better free programs out there. Go to a site called filehippo very help full. and last but not least you can do a fresh install of vista.
When i start up my computer it freezes
vista requires certain specifications to run properly. If you are trying to run this on a computer which is too old then it will quite often stop responding.example you need 1Gig RAM or higher, etc.
viruses are also one of the causes why windows would run slow, you should try a registry cleaner to fix registry problems.
Apr 24, 2011 | Microsoft Windows Vista Home Premium with...
Trying to convert wma files to wmp files so that they can be played on external player
if provided with an audio cd/dvd then windows media player can rip the wma files to wmp files but if you have the files on the drive then you will need an external converter for that purpose.
Jun 30, 2010 | Microsoft Windows Vista Home Premium with...
My WMP 11 on Vista will not recognise my philips
Could be driver problem. You can try reinstalling the driver for the device. If it's a vista system, you might want to run the executable file in administrator mode, or even change the compatibility to XP.
Uninstall the current installation of the device software.
  • Insert CD in CD-ROM
  • Right click on the setup file
  • Choose properties / Compatibility Tab
  • Set it to XP
  • and tick the box at the bottom run as administrator.
I hope that help.
Aug 16, 2009 | Philips HDD1630 MP3 Player
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
NO AUDIO OUTPUT DEVICE IS INSTALLED
its a known issue --if you u upgrade vista home to vista ultimate.just u need to uninstall the audio driver and install it again
Dec 22, 2008 | Microsoft Windows Vista Home Premium with...
Sansa e260 and Windows Media Player 11 Issue
What you need to do is to uinstall the device completely from the computer..once you have the device remove, open your windows media player click on tools, options, go under privacy,clear the history and caches...and then reinstall the device back...let me know if that doesnt help yo
Please rate accordingly
Thank you
Computerrrep
Aug 16, 2008 | SanDisk Sansa e260 MP3 Player
Gateway MT3705 Notebook Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
