Question about Rainbow E series Canister Wet/Dry Vacuum
Vacuum clogged Just had new carpet installed. In trying to vacuum the carpet for the first time, fine particles have clogged the sweeper. I'm using a rainbow sweeper with water reservoir.
  • Rocky
    Rocky May 11, 2010
    So what is the problem? Are you having difficulty cleaning clogs? Yf yes - where are you having the problem?
    New Friend:
  • 27 Answers
If you are talking about the electric hose, try using your none electric hose with the crevice tool attachment to extract the particles from the other one. When using any of the hose please leave it running a few minutes to make sure everything in the hose moves through and does not stop midway through.
Posted on Jul 30, 2009
reddevil6
  • 1673 Answers
SOURCE: Rainbow SE
The clog may have over heated the motor, usually if you unplug it then after little while, try it again. If it still won't go, does the separator turn easily or is it bound up and won't turn. Take it off and see if the motor will run(without water) You didn't say which model you have, but some of the newer ones have a small shaft, on the water tank, to activate a switch when you put the water tank on. If it is gone, or didnot seat right, then it won't turn on.
Posted on Jan 15, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
  • 136 Answers
SOURCE: bissel carpet shampooer is not dispensing water
put it on the curb
Posted on Aug 26, 2009
  • 52 Answers
SOURCE: rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Posted on May 21, 2010
  • 694 Answers
SOURCE: Central vacuum won't start even
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Posted on Oct 12, 2010
Jusy shut off while using
Your sweeper may have overheated. I don't know what brand you have but I hope you weren't trying to vacuum pine needles from the Christmas tree. Pine needles are sticky and will clog up any vacuum sweeper. Check your sweeper to make sure the tubes (hose & pipes that carry dirt) are clean and clear. I used to service Oreck vacuum sweepers.
Dec 30, 2013 | Eureka AirSpeed Bagless Zuum
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Leifheit Rotaro Manual Carpet Sweeper
Do you know where brush cleaner attaches to the leifheit carpet sweeper. or do you have a pamphlet with instructions for carpet cleaner
Nov 20, 2008 | Leifheit Rotaro S Canister Vacuum
Brushes won't spin on carpet
belt is stretched replace the belt and all will be well
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Rainbow E series Canister Wet/Dry Vacuum Logo
94 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
