TV DO NOT RESPOND IN STANDBY MODE - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
What is the Brand name and Model number to your TV? Provide more details please.
Posted on Oct 25, 2012
Is it normal for an acoustic solution 24" LCD TV to stay for like 10seconds before coming up after switching on from the stand by mode?
10 seconds doesn't seem an excessive amount of time. Standby is supposed to be a power saving mode - the fewer parts of the circuit that are kept in complete readiness for switch on, the less power will be saved.
These days there is much prejudice against using the standby mode and it would be expected designers would respond to this by changing the internal arrangements so standby consumes less power so when the set is switched on it will take time for capacitors to charge and digital computers to fully boot and so forth.
Think of it not so much as a TV but as a computer. A 10 second reboot from the sleep mode wouldn't be so unusual...
If the TV works ok otherwise you probably have no worries...
Sep 06, 2017 | Televison & Video
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
I cant get it off standby mode
If it does dot respond to any of the manual buttons on the TV, it means that the power supply has detected a fault condition and is keeping it in standby mode for safety reasons so preventing damage until the fault is cleared, if it is new the retailer should give you a new replacement TV without delay but you will have to ask for it, as it will be unlikely that it will be offered in the first instance.
n.r.b.
Jan 24, 2014 | Televison & Video
My plasma's power light is orange and when I press the on/off button nothing happens. What should I try next?
Hello Sir, hi, when your TV's power light is orange, it's on "standby mode" meaning the power supply will not respond to any power switch press. the standby by mode can be anything, this could be that the TV is not receiving any signal, this could also be that some thing a part or a section of the TV goes bad that makes overload. This needs to be checked thoroughly, I cannot be particular on this section simply the trouble is to broad to explain, this needs a pro for checking, but if you want a quick answer, simply replacing the entire power supply board will restore the TV back.
Nov 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
The screen went blanc and would not respond. When switched on, the set goes into standby mode and does not respond
hit the side of the tv and if you can get it to come good for a sec then you have dry joints on the main board.
hope this helps
Nov 26, 2008 | Televison & Video
HLR5667 Samsung TV reverts to standby mode. Thereafter, TV does not respond to remote.
Replaced power supply board to fix that problem in the past and never heard back from customers. Must have worked. Good luck, Russmann.
Nov 05, 2008 | Samsung Televison & Video
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
