Question about Bosch Dishwashers
Error 15 on a Bosch SMS65E12GB Dishwasher after it drew water whilst idle causing a flood
Flood in kitchen after machine drew water when machine idle at night. E 15 error showing How can we get rid of the Error 15 to try machine again
  • 1003 Answers
SOURCE: Indesit D43 Dishwasher
REPACE FLOAT SWITCH
Posted on Jan 18, 2008
dutchman05
  • 487 Answers
SOURCE: diplomat 8352 water not draining
your pump is obstructed. take out pump and clean it out. Your filter might be plugged too. As soon as it floods it also can be a leaking hose from the pump.
just open the machine and you will see the pump straight away.
Not difficult
Posted on Apr 26, 2008
SOURCE: F1 error
help
Posted on Jun 06, 2008
  • 174 Answers
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Posted on Jul 22, 2010
  • 311 Answers
SOURCE: I have a KitchenAid Drawer
Dry out the base of the unit.
Posted on Sep 24, 2010
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
Bosch dishwasher contiuned to flood all night...
It sounds like the float is stuck. Look for a round disk on bottom of dishwasher ( inside) Push it down and lift it up to make sure it is traveling without getting stuck. It is suppose to rise and then cut off water.
Mar 25, 2014 | Dishwashers
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
Dishwasher cycles through all programs but will not drain or turn off at the end of cycle. I do not know if it drains inbetween. It just continues to run on 0 minutes and when I turn it off and open there...
underneath the machine there is a donute shaped styrofoam item called a flood safty switch .makke sure there is no debri underneath..mice will drag animal food or chew on this and will lodge it leaving debri under it causing it to trigger a false flood condition causing the machine to go in to a continual drain-is there a digital readout on your machine reading 88 continuasly
Aug 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher = machine on but no water, so the lower basin has water in it and because of it the FLOOD CONTROL SWITCH IS ON, so how do I drain the rest of the water so the FLOOD CONTROL SWITCH goes...
If you can see the water use a shop vac if not you will have to pull the unit out and remove the left side panel after removeing the water you will need to find the leak that caused the bottom to fill with water
Mar 29, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Check water indicator remains illuminated on bosch classixx dishwasher?
caused by anti flood device. machine had water in base caused by minute leak on input hose dribbling down into machine.
Apr 21, 2008 | Dishwashers
Bosch dishwasher model shu3300
Your machine has detected a "flood" condition and has defaulted to its flood mode. Meaning that only the drain pump will work until the flood is fixed.
Bosch D/W's are pretty slick, the entire unit is sitting inside a drain pan that's designed to catch an overflow (flood) keeping the water off of your floor. This overflow pan has a Styrofoam float that rises with the flood and trips the "flood mode". The water in the pan has to be removed allowing the float to drop back down before you can use your dishwasher again.
There are 2 ways to do this... the easy way and the hard way.
1.) Easy way---> Wait a few days. The water will eventually evaporate out of the drain pan all by itself. Takes longer than the hard way, but no tools are involved.
2.) Hard way---> (not actually "hard") TURN POWER OFF TO THE DISHWASHER! Remove the lower kick panels (below the door). Remove the 2 screws holding the water valve in place, and push the valve up as far as you can. Now use a "Shop-Vac" with a long crevice tool attachment. Stick the crevice tool in where the valve was... make sure to reach in there about 8 or 9 inches, (the safety float is in there on the left, you can see it with a flashlight) otherwise it won't reach the water. Now simply suck up as much water as you can. You won't be able to get it all, you just need enough removed to drop the float.
Now try your D/W... after a normal 2 minute drain, it should fire right up.
Nov 04, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
