Question about Ryobi 18v Cordless Drill - P206 18 Volt V
Cdi-1801 hi i have a cd1-1801 18v drill and im looking for a replacement trigger assembly would you have any idea where i could get one ive been looking all over the net.... thanks
My Rigid 18v drill has lost power even after full charges. There also seems to be a dead spot when I pull the trigger. In other words, at a certain point when the trigger is pulled the drill shuts off so I...
the trigger mechanism is either worn or dirty, this wouldnt be a battery issue. the batteries in the pack depending on how old the drill is are probably nicad batteries. they will loose their pep after repeated cycleing over time. ive seen people replace the batteries in the packs if your handy with a soldering iron if not new packs are the answer, for the switch, if you dont want to dis assemble and clean, try blowing it out with air hose around the trigger area
Jan 31, 2010 | Drills
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Myn60fn is leaking from around the trigger, do I have to take the whole thing apart to replace the o rings or do I just drive out the spring clips?
You will need to remove the trigger before driving out the roll pin. After you remove the trigger and roll pin, place a rag over the trigger, remove your hand from the area, and briefly hook up your air line. (Clean your soiled pants after this part) You will hear a loud pop and the trigger assembly is going to come out quickly. If you are not prepared for this it will scare the **** out of you. Then once you have the trigger assembly out you can push the two retaining pins on the assembly out and remove the inner workings of the trigger. One note of caution. The ring you are trying to replace is a hard half moon looking ring that Bostitch doesn''t sell separately. You may see it in pieces when you take this assembly apart, or you may not. Sometimes it crumbles and comes out of the trigger exhaust. You can try to match up an oring to sit in there, but from experience it is much easier and less costly to just order the whole trigger valve. Hope this helps.
Sep 29, 2009 | Stanley Bostitch N88rh Framing Nailer...
Drilling a 2008 aprilia rs125 cdi unit
when you look at the cdi you should se a recess in the corner just a small little recess , enough for a small drill bit to fit , drill the small nipple located in the recess
and i am no expert , just persistent at researching the net
Jul 01, 2009 | 2008 Aprilia RS 125
NEED NEW TRIGGER SWITCH
Ryobi has their own website to go on for any part that you need. You need to know all info on the drill like yr., make ,mdl. etc... I purchased a switch for my ryobi table saw and they shipped it quick and the parts are inexpensive.
May 26, 2009 | Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Kawasaki 19.2 cordless drill
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Ryobi 18v Cordless Drill - P206 18 Volt V Logo
29 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
