Question about Home
Older Waltec tub shower 'growmax' needs replacing
From 1970''s - 1980's Waltec manufactured the 'gromax' used to adjust water temperature. There was a 3 knob vertical configuration. The top knob regulated shower strength, on + off. The bottom knob regulated the tub strength, on + off. The middle knob regulated the temperature, hot or cold for either the shower or tub, which ever was selected. I would like to see the plumbing configuation behind the wall and want to know what to use to replace this old system, as they are no longer made. (It's really too bad as they worked great and had a safety feature for young ones. If someone has one lying around on a shelf I would love to buy it!) I'm not sure how to spell 'gromax'? This is for my Mom's bathroom in Canada.
  • Dennis Koroll Oct 26, 2012
    The thing is that the gromax part which I'm not sure how to spell is very old and no longer made, are there any plumbing suply places who have dealt with these parts (gromax)?
frcs68
  • 1605 Answers
SOURCE: hot and cold water in shower comes out in a triclkle
shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Posted on Jan 07, 2009
  • 659 Answers
SOURCE: Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Posted on Mar 22, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: Have no Cold water coming out of shower/tub.
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Posted on Mar 16, 2010
  • 12650 Answers
SOURCE: When turning on the shower faucet there is no hot water.
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Posted on Mar 24, 2010
Testimonial: "This information was extremely helpful especially when you know what to look for and have instruction."
  • 349 Answers
SOURCE: adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
Posted on May 05, 2010
What brand plumbing in shower
most taps for bathrooms have replaceable spigots and handles of various design that suit the shaft. I would be talking with a plumber as to what you have and as to why any spigot assy will not fit. Even if you have ceramic inserts they still fit the tap proper.
Jun 17, 2013 | Home
How do i install tub/shower remodeling kit 9B-3H/C
while the wall is open is the time to replace the plumbing it's cheaper to do it know then in a few weeks when its all closed in $100 now or $500 later
Oct 14, 2012 | Price Pfister Verve Tub & Shower...
Grohe avensys dripping
Hi Bryan,
The leak you're seeing originates at the hot / cold water valve(s) itself. Most newer homes have valves that automatically adjust the temperature of the water to prevent scalding. Your Grohe Avensys, like many reputable makers, have warranties on their products and may make replacement parts available for free - if you are still under warranty - by call their customer support lines.
Generally, you will not be able to get free replacement parts at a hardware store, plumbing supply store, etc. You must call the manufacturer directly. Of course, you will have to pay for these parts at those retailers - if the valve is out of warranty, been replaced by the manufacturer under warranty previously, etc.
Your first step will be to identify the valve model. This information may be near the manufacturer's name - or may require locating the manufacturer's web site for visual comparison. Either way, you'll probably need to contact the customer service representatives to get help with replacement parts. They should be able to select the parts that you need to solve the problem and provide them along with printed removal & installation instructions.
Contact links for Grohe USA & Canada
Contact links for Grohe UK
I hope this helps & good luck!
Aug 31, 2012 | Home
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
We had a new battery put in our 1999 lincoln navigatior and the rear air suspence went down and we can not get it to to fill back up
Replace the entire Air Suspension with
conventional shock/struts such as Strutmasters
or other brands
You do not even diagnose a Navigators Air
Suspension after the vehicle is 5 years old
Dealers can't figure it out
Next time you get the Ford version.
Still issues but nowhere near anything
that is installed on a Navigator
A Navigator is like an Oldsmobile from
the 1970's & 1980's A test bed of poor choices,
bad engineering & ideas
May 29, 2011 | 1999 Lincoln Navigator
When I turn on the tub faucet, water comes out of the spout and shower head. It's a t215.710 model
Does it have a diverter on the spout? If so, replace the spout with the same type. If it is a new installation, did you make up the valve or was it complete and designed for tub & shower? If it's an old valve and it has a separate diverter stem, there is a spacer behind the valve between the valve housing. Replace it.
Apr 21, 2011 | American Standard Plumbing
Have a moen tub faucet put in new o-rings and now it wont stay pushed in to turn off this is a older model that just pulls straight out then turns l/r for hot & cold
a possible problem,there is some thing else in there,take apart again and look in there and maybe flush it out before you put it back together
Feb 20, 2010 | Moen & One Handle Tub & Shower Faucet
Home Logo
105 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
