I have a 32" Avol TV that I'm using for my PC Monitor. It keeps changing from source VGA to a blank screen, then it says no device. I have to go to Source and change it back to VGA. What can I
thebartman58
  • 4 Answers
SOURCE: The source keeps changing automatically
this does seem to be a heat issue,
Posted on Nov 28, 2007
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 8 Answers
SOURCE: Protron PLTV-32 Television source changes on it's on.
This is NOT an electrical issue. Anyone who is half handy with their hands can easily fix this.
I had this issue for awhile, and I just figured it out. There is a plastic strip that cover the the buttons on the tv. They want you to think it is a touch panel, but it isn't. Anyway it is glued on, not screwed or attached in any other way. The reason it keeps changing the source is because the glue expands when it heats up, and causes to source button to be pressed. There are several ways to fix this. You can remove the strip which is long about the length of the tv. Stick a knife or screwdriver under one end and slowly pull it off. Problem is solved, but it makes the screen look ugly. The way to fix this is by using a razor or knife and cutting off the glue (which is really tape) under where the buttons are. You can replace it with better glue, or just eliminate the glue from under the buttons and keep the glue on both ends, so you can re-attach it to the tv.
Posted on Dec 04, 2008
jamielwright
  • 75 Answers
SOURCE: Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Posted on Jun 01, 2009
budmrtn
  • 11361 Answers
SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
Posted on Nov 03, 2009
How do connect my Dell Netbook, approximately 8yrs old, to my Avol 42" tv. Please help!
On the laptop keyboard,checkfor one of the f keys, one of them shoulld have 2 square, one blank and one dark, on my laptop is f5, so when I connect my vga to an external monitor, I press and hold FN key and f5, in the laptop, the display should prompt me which to use.
Have in mind this method could change, not all laptop works the same, but close enough for you to handle it. Good luck.
Jan 17, 2015 | Dell Televison & Video
Want to use my tv as a monitor, how do I activate the vga output?
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope it helps
Jul 20, 2012 | ASUS Eeepc Eee Pc 1005 1005h 1005ha...
My pc wont recognise my tv as a second monitor - conected with VGA cable
the video card you used have a capability for dual monitor..so 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
Jan 31, 2012 | Dell Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
HOW TO GET NETFLIX ON MY TV FROM PC
Your TV should have a VGA port as one of its inputs. So your TV will act as a very big monitor. All you need is a VGA cable. If you are using a desktop computer, you can use the same VGA that you use to connect the computer to the monitor. If it's a laptop, you will need to find a VGA cable to use.
Remember to switch the TV input to the VGA source, usually listed as PC on newer TV's.
Good luck.
Apr 27, 2011 | LG 3270 32 in. HDTV LCD TV
Tv is on when plugged in but doesnt respond to any button inputs.shows "snow" on the screen but nothing more. Model is 42wp48a toshiba 42 inch plasma.
This is a display device or monitor only. It lacks a tuner, so there is no way to connect an antenna and tune off air TV channels - and as such; fails the definition of a TV. A TV by very definition is a monitor AND a tuner. Without the optional "RTB421 RCA Terminal Board" installed in the monitor, it can only accept a PC Input signal (VGA).
If the RTB421 is installed, you will be able to choose from PC, Video, S-Video and RGB signals. The full details on this RTB421 Terminal Board and how to connect source video devices for playback is explained on pages 32 through 35 of the manual.
If the RTB421 is installed, and connected to a source video device (Cable TV converter, Satellite Tuner, Blu Ray player, DVD, VCR, etc.) as shown in the manual, you should be able to scroll through the inputs by pressing the Input button on the monitor or remote (make sure the batteries are fresh). Keep the lower left bezel of the monitor clear of obstructions that can block the infrared (IR) remote receiver window.
I hope this helps and good luck! Please rate my reply - thank you.
Feb 27, 2011 | Toshiba 42WP27 42 in. Plasma Television
Screen won't come on
When u try it as a tv no picture,but does it have sound?Than ur LCD inverter board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter boad for the replacement.It a long board in shape.
May 11, 2010 | Philips 17MD255V Combo
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
