Question about Poulan P3500 17-inch 25cc 2-Cycle Gas-Powered Cut Twist and Edge C
Poulan p3500 pull cord - Poulan P3500 17-inch 25cc 2-Cycle Gas-Powered Cut Twist and Edge C
  • Neer Patel Oct 24, 2012
    How do you replace the pull cord? Mine broke when I tried to start the trimmer.
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: HOW DO YOU ADJUST THE CARBURATOR ON A POULAN P3500
Due to EPA regs, users are supposed to be restricted from adjusting carbs, but there are special tools provided by the manufacturers for this purpose. Only service techs are supposed to have them. Most carbs have an H and L adjusting needle on them. Some are Zama, some are Walbro and some are imitations of the 2. Some have "splined" heads, some have "Pac-Man" type heads (with small V-cut in them), and some are "D" shaped. With some ingenuity, one can fashion a tool to use to remove some of them. Small aluminum tubing can be forced over a splined head needle and turned. Small jewelers needle-nose pliars also may work.There are sellers that have tools for all these carbs. I would like to refer you to the Zama carburetor adjusting tech page.
http://www.zamacarb.com/tipspage.html
Posted on Sep 26, 2010
#1 Taper
  • 1041 Answers
SOURCE: how do you restring when the string runs out?
Try my Tip on this subject; it may help:
www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
Jim
Posted on Aug 15, 2011
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
Replace Pull cord poulan p3500
Hook the cord into the small cut a way in the side of the pulley, now wind the pulley in a clockwse direction you should feel the the spring tention increasing, once there is adiquate tention unhook the rope from the pulley and allow the spring to wind the pulley back and pull the cord in, do not forget to replace the screw and plate that secures the pulley as it appears to be missing on your video.
May 26, 2013 | Garden
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Jammed pull cord on Poulan P4018 chainsaw!
There maybe a split pin holding the cover down over the spindle! Not too sure, but possible. Could be pushed down the centre, just a case of having a good look. Only really worked with Hurqvarna's and Makita's. Hope it helps. Good Luck
RICH
Dec 16, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Poulan P3500 17-inch 25cc 2-Cycle Gas-Powered Cut Twist and Edge C Logo
44 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
