Question about Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp
Engine idoling way to high - Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp
  • 430 Answers
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
Posted on Oct 25, 2012
Oil light on, low cool lant flashes, did oil change, flush radiator?? Now my engine runs hard and it sounds like it's idling hard. High idol and low idol ?? Help!
I would not drive it in case the engine died, the symptoms you describe are indicative of possible cylinder head issues.
Get a GOOD garage to visit or have them tow it into their premises to check your vehicle over.
Jul 09, 2015 | Cars & Trucks
My welding machine will not idol down .Only stays in high idol. Why won't my machine idol back down when not welding? Yes I have the switch on run / idol lol 225 bobcat miller Kohler engine
Possibly the idler control circuit board. I changed out my fair share back when I worked on them. Also, check your idler solenoid. I can't remember if those pulled in to idle, or pulled in for high RPM's. May be something as simple as rust on the solenoid plunger.
Dec 15, 2014 | Welding Tools
My welding machine will not idol down. Only stays in high idol . Why won't my machine idol back down when not welding? Yes I have the switch on run /idol lol 225 bobcat miller Kohler engine
put 12 volts to the coil and see if it pulls in. Could be coil, idle module, ignition switch, or wiring. Get a 12v test light and trace it.
What can cause a 97 aurora olds. To idol high in drive?
Hi, Check for any Vacuum leaks. This can cause for engine to idle high or even rough. One other thing is a bad idol air control. Hope that helps. Go to your mechanic and have him do a computer code check.
Oct 23, 2014 | 1997 Oldsmobile Aurora
I have a briggs engine model 282h07-0196e1 . the engine will not run at high rpm
Hi your governor spring is probably broken, it connects the throttle plate to the throttle shaft assembly. regards Phil
May 30, 2012 | Garden
Idol very high 3000rpm possable idol sensor
throttle positioning sensor voltage should run around 1 volt at idle. If you unplug the sensor the car should still run on the presets in the computer, this will turn on the check engine light but if the RPM's drop down to normal replace the tps.
Jan 19, 2010 | 1999 Saturn SL
Car looses power or bogs down and then the check engine light comes on and it smooths out. light comes on and turns off. idol is a little high.
You may need a new fuel filter. This is a symtom of insuffcient fuel, hence the high idol due to lean fuel mixture. Change it first & see if this solves the problem. Good luck!
Dec 29, 2009 | 1989 Chevrolet Camaro
Car idols high at start some times, slow to
3.1 AND 3.8 ARE KNOWN FOR UPPER AND LOWER INTAKE GASKETS
Jun 24, 2009 | 2000 Pontiac Grand Prix
High idol when cranked
the idle controll sensor is on the intake manifold replace it and reset codes
Jan 09, 2009 | 2000 Ford Explorer
Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp Logo
235 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
