Question about GMC 2004 Envoy XUV SLT
Where is the fuse for accessory air inflator, 2004 envoy xuv
SOURCE: 2004 Envoy AC works but does not come out the front vents. Only @ windshield
You most likely have a bad mode actuator. http://forums.trailvoy.com/showthread.php?t=40235
Posted on Sep 26, 2008
SOURCE: 2004 envoy xuv tailgate problems
the actuators have a white stem that sticks out of the bottom of them. if you push up on the ones on the driver side it will open the back hatch for you.
Posted on Dec 18, 2008
Molson02536
  • 3854 Answers
SOURCE: What is the biggest tire that will fit a 2004 GMC Envoy
Stock Tire - 245/65R17
Revs per Mile:704.3
Overall Diameter: 29.53 in 750.06 mm
Actual Speed: 60 mph 100 km/h
Tire 1 - 275/60R17
Revs per Mile:693.5
Overall Diameter: 29.99 in 761.74 mm
Speedometer1: 59.0 mph 98.4 km/h
Speedometer Difference: 1.557% too slow
Diameter Difference: 1.54%
Will fit with the stock rims.
Posted on Dec 14, 2009
SOURCE: fuse
The second fuse panel is under the rear seat.
Posted on Jan 07, 2010
  • 3600 Answers
SOURCE: 2004 GMC Envoy XUV mid-gate window won't roll up
be sure the gate is fully closed or it will not roll up if it is firmly in place and still does not go up you will have to remove the cover and see if the actuator plastic has broken off from the switch, it also could be a bent rod and or the switch is bad. Check fuses as well just to be sure before going to all the other work to pull cover off. Hope this is helpful and thanks for using Fix-ya.
Posted on Jan 19, 2010
How to fix my rear tailgate window
check the fuse/relay. if it is neither of these check the switch with a multimeter. If you can hear the motor trying to move the glass when you try the switch it may be the regulator needs attention. It may be the motor needs to be replaced.
check fuse and relay along with the switch first then the regulator and motor afterwards. Replacing the small electronics is obviously easier than having to open up the tailgate to check the mechanics of the winedow.
Sep 13, 2015 | 2004 GMC Envoy XUV
2004 envoy xuv low beams went out all other lights work checked fuses and switched relays 45 and 46 and still not working any ideas?
Try to see if the bulbs blew out by replacing the bulbs first. If they still won't light, it could be bad grounds or connections or bad continuity in the wiring to the headlight relays or switch. Good luck on this repair.
Dec 11, 2011 | 2004 GMC Envoy
What is the fuse number that powers the stereo for a 2004 GMC Envoy XUV
Fuse #41 in the rear fuse panel located under the rear seat.
Feb 16, 2011 | 2004 GMC Envoy
How i can change de air condition filter in envoy xuv 2004
There is no fresh air filter in the Envoy
Nov 06, 2010 | 2004 GMC Envoy
2003 gmc Envoy Low Beam Headlights both quit at the same time. Checked fuses and replaced bulbs. No dice. ????
Relay in fuse box under hood on driver side wheel well labeled HDM, #46 on 2004 Envoy XUV. Swap with relay #45 labeled "Fan" to test. That was my problem.
Good Luck,
Sam
Jul 01, 2010 | 2004 GMC Envoy
2004 Envoy xuv 6 cyl stalls with A/C on at idle
2004 Envoy xuv 6 cyl when I turn on the A/C the truck stalls but as long as I keep my foot on the gas it will continue to run
Jun 11, 2010 | 2004 GMC Envoy
I have a 2004 xuv envoy with 115k miles. The
i would say it's long overdue. i would think the manufacturer would recomend changing the trans fluid at 25,000-30,000 miles. the owners manual will have regularly scheduled maintenance routines listed.
Apr 05, 2010 | 2004 GMC Envoy
Jan 19, 2010 | 2004 GMC Envoy
GMC 2004 Envoy XUV SLT Logo
Top GMC Heating & Cooling Experts
Doug Adams
Doug Adams
Darrell
Stan Ford
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
