Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Replacing heating element in oven-connecting wires fell back in
While replacing the heating element in my Viking heating element one of the wires needed to reconnect the element fell back inward and I cannot locate it through the hole in the back of the oven. Do I need to move the whole oven away from the wall (which would be an issue) or can I remove the back panel of the oven...Help
    Sergeant:
  • 311 Answers
Hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Posted on Jan 02, 2009
Heating element disconnected
Make sure to keep breaker to oven off because wire could short against back of oven and start a fire. You need to disconnect the tilt bracket and pull the oven out. Replace the clip on the wire if needed. Make sure to reattach tightly. Put it back in the wall, reattaching anti-tip bracket. It should work.
Jun 02, 2014 | GE JRP24 Electric Double Oven
Viking profesional convection oven doesnt work
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Apr 17, 2014 | Viking Professional Select VESO130SS...
Viking Professional
1.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
2.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
3.
4.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
The bake element
Oct 20, 2013 | Viking Ovens
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Jan 11, 2011 | Frigidaire Ovens
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    I am replacing the lower oven baking element. After pulling the defective one out, I find no female receiver for the male connection tabs on the element. Are they loose wired? I am used to just plugging...
    They probably are loose wired unless you see a porcelain receiver for them... it is CHEAPER so they do it! Maintainability? None !!!
    With power disconnected, you MIGHT be able to "fish" the leads back out and attach before mounting the element.
    Oct 17, 2009 | Viking VEDO205 Electric Double Oven
    Stove oven wont work..
    Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
    You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
    Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
    Hope this help you! :)
    Apr 11, 2009 | Viking Stove/Oven/Range Timer Knob -...
    Lower oven does not work. Ind. light comes on but no heat
    It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
    Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
    416 people viewed this question
    Top Viking Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
