Question about Measuring Tools & Sensors
How can i get the lower guard assembly 089100207702 spring installed correctly
Had to replace the lower guard assembly and cannot get the spring installed correctly.
rowdy45176
  • 2176 Answers
SOURCE: Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Posted on Dec 24, 2008
CDNMoose
  • 15 Answers
SOURCE: Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Posted on Feb 19, 2009
brewerstool
  • 141 Answers
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
brewerstool
  • 141 Answers
SOURCE: repair spring to lower guard to spring back
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Posted on Oct 28, 2009
agent91
  • 2100 Answers
SOURCE: I reassembled the blade guard after cleaning and
Had the same problem with the dewalt, either the lifter arm is bent just enough or some thing is worn just enough, we put a zip tie on the part where the saw comes up to rest and it works fine.
Posted on Mar 14, 2010
Steps to replace 2007 dodge dakota tront shocks from strut spring assembly
Hello Russell,
If you replacing the front struts as an assembly the springs will be equipped and ready to install.
If your purchasing the strut assembly without the coil springs you will need a spring compressor.
  1. Before servicing the vehicle a service manual for safety precautions should be consulted.
  2. Raise and support the vehicle.
  3. Remove the tire and wheel assembly.
  4. Support the lower control arm outboard end.
  5. Remove the upper shock nuts.
  6. Remove the stabilizer link lower nut and then separate the stabilizer link from the lower control arm to gain access to the lower shock bolt.
  7. Remove the lower shock bolt.
  8. Remove the shock.
To install:
  1. Install the upper part of the shock into the frame bracket.
  2. Install the nuts. Tighten to 45 ft. lbs. (61 Nm).
  3. Install the lower part of the shock into the lower control arm. Tighten the bolt to 155 ft. lbs. (210 Nm).
  4. Install the stabilizer link lower nut to the lower control arm.
  5. Remove the support from the lower control arm outboard end.
  6. Install the tire and wheel assembly.
  7. Remove the support and lower the vehicle.
Jul 27, 2016 | Dodge Cars & Trucks
Toro LX468- Was replacing belt and a small (2") spring came loose from I think the PTO ? Also the PTO clutch should be in what position to permit belt guard installation? Does the guard go into the gr
Yess it goes into the groove to prevent clutch housing from turning and the position of the housing when install the retaining bolts.
The spring into the hole on the clutch housing and other end goes somewhere on the frame. It is being used as a damper spring.
The below should be correct.
Oct 23, 2014 | Toro Garden
Install spring on 345 guard
As you are looking at the blade side of the saw, the spring hooks through a hole at about three o'clock on the lower guard. It then wraps around the bottom of the guard clockwise and attaches to the upper guard. The hole on the upperguard should be somewhere around ten to twelve o'clock. Move the lower guard to check for binding and full return to the safe position.
Feb 21, 2012 | Saws
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
How to replace the rear shocks on a 1998 nissan maxima
REMOVE REAR SEAT AND PACKAGE SHELF TO GAIN ACCESS TO THE UPPER SHOCK ATTACHING NUTS.REMOVE UPPER ATTACHING NUTS. RAISE VECHICLE REMOVE REAR WHEEL AND SUPPORT THE LOWER CONTROL ARM WITH A JACK REMOVE LOWER SHOCK ABSORBER MOUNTING BOLT. REMOVE SHOCK ABSORBER ASSEMBLY FROM THE VECHICLE. COMPRESS THE COIL SPRING WITH THE PROPER SPRING COMPRESSOR TOOL. REMOVE CENTER RETAINING NUT HOLDING THE UPPER MOUNTING INSULATOR. SLOWLY DECOMPRESS THE COIL SPRING.REMOVE THE MOUNTING INSULATOR AND THE COIL SPRING. REMOVE THE COIL SPRING. TO INSTALL COMPRESSED COIL SPRING ONTO THE STRUT ASSEMBLY. BE SURE TO THE END OF THE SPRING IS IN THE NOTCH ON THE LOWER SEAT.INSTALL UPPER MOUNTING INSULATOR. YOU WILL NEW LOCKNUT FOR THE CENTER RETAINING NUT OF THE COIL SPRING. CENTER RETAINING NUT AND TORQUE THE NUT TO 13 TO 17 FT LBS. SLOWLY REMOVE THE SPRING COMPRESSOR TOOL. INSTALL SHOCK ABSORBER ASSEMBLY IN THE VECHICLE AND INSTALL THE MOUNTING FASTERNERS AND TORQUE LOWER MOUNTING BOLTS TO 72 - 87 FT LBS. INSTALL WHEEL.LOWER VECHICLE. WARNING COIL SPRING UNDER EXTREME LOADS WHEN COMPRESSED.BESURE TO PROPERLY ALIGN THE SPRING WITH THE COMPRESSING TOOL TO PREVENT PERSONAL INJURY FROM THE SPRING RELEASING UNEXPECTEDLY.
Feb 02, 2011 | 1998 Nissan Maxima
How do i replace my tension spring on my makita 5007F circular saw? i put it on but it keeps falling off. what step am i missing?
is the spring stretched?? there are 2 holes one in the lower guard and one in the upper guard assembly towards the back that you have to put the bend of the spring in
Oct 02, 2010 | Makita Saws
Picture or directions for repairing rear drum brake
Brake Shoes Removal & Installation Duo-Servo Type To Remove:
  1. Raise the vehicle and support it safely.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drums.
  4. Using a brake tool, remove the shoe return springs.
  5. Remove the shoe guide.
  6. Remove the hold-down springs and pins.
  7. Remove the actuator lever and pivot.
  8. Remove the lever return spring.
  9. Remove the actuator link, parking brake strut, spring retaining ring.
  10. Remove the parking brake lever and washer.
  11. Remove the shoe assemblies.
  12. Remove the adjuster screw and spring from the shoe assembly.
To Install:
  1. Use brake cleaning fluid to remove dirt from the brake drum. Check the drums for scoring, cracks and for out-of-round; service the drums as necessary.
  2. Check the wheel cylinders by carefully pulling the lower edges of the wheel cylinder boots away from the cylinders. If there is excessive leakage, the inside of the cylinder will drip fluid; repair or replace as necessary.
  3. Check the flange plate, which is located around the axle, for leakage of differential lubricant.
  4. Lightly lubricate the parking brake cable, parking brake lever where it enters the shoe and the backing plate-to-shoe contact points. Use high temperature, waterproof, grease or special brake lube.
  5. Install the parking brake lever into the secondary shoe with the attaching bolt, spring washer, lockwasher, and nut. It is important that the lever move freely before the shoe is attached. Move the assembly and check for proper action.
  6. Lubricate the adjusting screw and make sure it works freely.
  7. Connect the adjuster screw and spring to the bottom portion of both shoes. Ensure the spring does not interfere with the adjuster rotation when installed. The primary (smaller shoe pad area) to the front and secondary shoe (larger shoe pad area) to the rear of the vehicle.
  8. Install the shoe assembly. Ensuring the shoe webs are positioned correctly against the wheel cylinder.
  9. Install the parking brake cable.
  10. Secure the primary shoes with the hold-down pin and spring.
  11. Install the parking brake strut and the strut spring.
  12. Install the actuator lever and pivot, securing the assembly with the hold-down pin and spring. Install the actuator link and spring.
  13. Install the return springs.
  14. Check the operation of the self-adjusting mechanism by moving the actuating lever by hand.
  15. Adjust the brakes and install the drum.
  16. Adjust the parking brake.
  17. Install the tire and wheel assembly.
  18. Lower the vehicle.
Leading-Trailing Type To Remove:
  4. Raise the lever arm of the actuator until the upper end is clear of the slot in the adjuster screw.
  5. Slide the actuator off the adjuster pin. Disconnect the actuator spring from the shoe.
  6. Remove the hold-down spring assemblies and pins.
  7. Pull the bottom ends of the shoes apart and lift the lower return spring over the anchor plate. Allow the shoe ends to come together and remove the spring.
  8. Remove the shoe assembly, along with the upper return spring and the adjusting screw assembly.
  9. Remove the upper return spring and the adjusting screw assembly from the shoes.
  10. Remove the retaining ring, pin, spring washer, and parking brake lever.
Typical rear drum brake assembly (Leading/Trailing type) 93026g52.gif
To Install:
  1. Clean adjuster wheel and the backing plates with a suitable cleaner. Lubricate the backing plate contact points, levers and adjuster with a suitable lubricant.
  2. Assemble the parking lever, spring washer (concave side facing the brake lever), pin, and retaining ring onto the rearward shoe.
  3. Install the adjuster pin in the forward shoe with the pin projecting 0.276 in. (7mm) from the side of the shoe web where the adjuster actuator is installed.
  4. With the brake shoes resting on a flat surface (the shoe with the parking lever to the rear of the vehicle), install the upper return spring.
  5. Install the adjuster screw assembly with the spring clip facing the backing plate.
  6. Place the shoes in position on the backing plate. Do not place the lower shoe webs under the anchor plate.
  7. Install the lower return spring, spread the bottom of the shoes and position the shoe against the backing plate.
  8. Install the hold-down pins and spring assemblies.
  9. Install the adjuster actuator over the end of the adjuster pin so the top leg engages the notch in the adjuster screw.
  10. Install the actuator spring, being careful not to over-stretch it more than 3.27 in. (83mm).
  11. Install the parking brake cable to the lever.
  12. Adjust the parking brake if the shoes will not totally retract.
  13. Install the drum, tire and wheel assembly. Adjust the rear brakes and lower the vehicle.
Aug 17, 2010 | 1999 Chevrolet Suburban
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
Remove and replace rear brake shoes on 2004 honda accord
Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
