Electrical system in ovarload protection. Paslode suggest disconnecting and reconnecting the fan. Tried this and it didn't work. Any other ideas?
SOURCE: no action. fresh battery and gas paslode framing
Check the small switch at the top by the fan . It has a small roller on it.This trips the switch for ignition. Lightly bend the arm in a small amout so that when the tool is compressed the switch will be activated
SOURCE: Paslode works intermittently
I had a similar problem with my impulse framer. The solution was to adjust the battery contacts within the gun. The contacts were not making good connection with the battery. I also adjusted the safety foot out to max so that the trigger mech. could function more reliably. Other problems I have had with this gun were related to the proper seating of the fuel cylinder and condition of the battery. My battery would no longer hold a proper charge causing the red light error.
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
SOURCE: My paslode im 350 framing nailer is firing only 1
when was the last time serviced, could be dirt or a dry cylinder, also the o rings might be worn not allowing it to seal properly and also check the expiration date on the fuel cell. All of these could be the problem, let me know and you can also go to Paslode.com and type in your model number for an owners manual with a troubleshooting guide in the back.
SOURCE: impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
Bad o-rings or bent firing pin...
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
l;';[]
