Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
Canon mg2120 scanner is disconnected message error code 5,156,61
Printer works, but low on black ink. scanner worked and I reinstalled everything. Scanner says it's warming up, but then gives me error message stating the usb connector is disconnected or the scanner is not online.
SOURCE: Canon MP145:Stop error E5 , use scanner only
THIS SOLUTION FOR PEOPLE WHO CANNOT RESET THEIR OWN PRINTER LIKE ME
hi, now i got a solution how to SCAN if your printer have E-5 error or something. First u must remove the both cartridge from your printer and make sure u connect your printer to your computer, after that, do this
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
And then you will see no error in your printer (the LED shows number 1,and the alarm is in green)
NOW U CAN SCAN USING MP NAVIGATOR!
Posted on Apr 28, 2010
SOURCE: Canon MP150 scanner problem.
I had the EXACT same problem at first and I somehow solved it. All I did was restart the computer, unplug the cables and replugged them again. Started MP navigator and it worked!
Hope this will help.
Posted on Dec 06, 2008
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
cene765
  • 787 Answers
SOURCE: canon printer problem
Scanner not work because printer need recognized both cartridges.In your case color cartridge is defective.Replace it and the message will disappear.
Posted on Oct 21, 2009
SOURCE: Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Posted on Dec 22, 2011
Error 2,156,50 canon mg 2120
because I can not always quick scan shows me the error 2156.50
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
I have a problem on my canon mp145 with an error code E4. But I already change it to a new cartridge but still the error code still appears. I also reinstall the drivers but still the same.
Hi, I found this answer on the net. Let me know if this helps
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY. Below are the manual way to correct this problem : Turn On Your Printer. Wait Till The Printer Led Screen Show The Error Code ( E4). Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Thanks
Ranjit
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error 4
The error code E4 indicates that ur printer is low on black ink if ur getting this error error code then u need to replace the blak ink cartridge. Hope this solution will solve ur prob
Jul 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Black ink low, error message 5200
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E5 and 2,114,0 errors on Canon MP160
I got this Error 2,114,0 with my MP210 and none of the above fixes worked. This is how I have got it working again: Press and hold the maintenance (picure of spanner and screw driver) button and the reset button ( Inverted red triangle) together for five seconds or more. The flashing error code 1 and 6 will then stop flashing and replaced by a print copy no 1. The printer/scanner is reset and the scanner works.
Feb 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
1,790 people viewed this question
old marine
old marine
