Question about White Sewing 2200 Multi-Tasker
Buttonholes on the 2200 singer - White Sewing 2200 Multi-Tasker
Singer 1036 1-step buttonhole foot. It will make 1 perfect buttonhole. When I try to make the next one it makes a short buttonhole, never moving forward enough to hit the lever.
Possibly your machine does not make repeat buttonholes and you need to set every time? Are you stitching all the way around before resetting.
Dec 17, 2016 | Singer Sewing Machines
Singer futura ce 200 buttonhole lever not stopping where it should
the buttonhole lever may need to be checked to see if there is something wrong with it
Apr 01, 2016 | Singer CE-200 Quantum Futura Computerized...
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
Singer 7258 will not sew automatic buttonholes. The needle goes up and down, but that's all. The buttonhole lever is down, so that's not it. Please help.
if the sewing machine is set on the buttonhole setting then it's
possible that the sewing machine motherboard has a problem.
or a part could be damaged, the machine may need some type
of adjustment.
Dec 01, 2012 | Singer 7258 Sewing Machine
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
Singer simple machine: buttonhole maker stitches in same place.
Have you read your manual and made sure that the buttonhole lever is pushed to the rear? Call Singer if you still have a problem, 1-800-4singer. Good luck
Jun 19, 2009 | Singer 5050 Mechanical Sewing Machine
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
White Sewing 2200 Multi-Tasker Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
