Washer leaks We have this washer,it is a Frigidaire When we now wash clothes water lies over our floor.Some how water is leaking out of the washer and it's not coming from the hoses.Could you please help me Conan
  • cjnagle Jan 02, 2009
    Thanks for the reply back,before you got back to me I called a repair shop from where I live and he told me the same thing as you did.
    So that's what I did popped the top took off the front of the washer so we could see inside it.
    The hole thing look brand new inside so we put it though a small load right through the hole thing,and guess what! not a drop of water came out from anywhere.
    So God willing it fixed it self.
    Thanks once more.
    for your time I would like to give you this link to look at.
    you can sine up for 7 days free to see if you like it.
    P.S. Interested in creating your own economy?
    http://store.sixminutestosuccess.com/?ai...
    Sergeant:
  • 311 Answers
You'll have to pop the top[use putty knife at crease above frount panel.]remove frount and watch opperation.you'll see where the water comes from.God bless,tom
Posted on Jan 02, 2009
I have a frigidaire atf6000es and while the washer is running water is running out in the floor
Hello Brandy Neal - Often a leak coming from underneath the washer would indicate a leak possibly in the hoses or in the tub. If the hoses are securely tighten then at this point I personally recommend consulting with a certified technician to narrow down the precise issue.
Mar 10, 2013 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer leaking water on floor
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Feb 11, 2011 | Frigidaire GLET1031WH Top Load Stacked...
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Leaking water from front door after cycle is done
If your washer is upstairs it's probably the washer drainpipe or the piping in the walls. Go look.
Oct 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine leaks when clothes are washed but not
this could be a simple issue or a severe issue.
if you feel adventurous disconnect unit, and remove Rear access panel. inspect the rear bearring at the pulley, check for oil leakage and water residue. if there is water around the bearring the unit requires an overhaul. if nothing you should be ok.
it could be a disconnected vent at the top of the machine.
remove front access panel and inspect all rubber boots and connections for water.
this is best done just after washer has leaked, inspect where water is comming from.
there are many things that could be causing this.
Jun 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Will not fill up with water
Check the exit hose behind your machine must be lying at floor level, this should not be. It must go over a certain height, approx 3 feet before it comes down to your drain. If you look carefully behind your machine you may find a water mark, the tube should go to this level & then down to your drain. Check this out.
Feb 22, 2009 | Roper RAS8445KQ Top Load Washer
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Washing Machines Logo
Top Washing Machines Experts
