Question about Dell Inspiron 6400 Notebook
Inspiron 64000 i cant acess your solution to my problem ,new battery not charging but computor ok while connected to mains regards joe kelly
    Novelist:
  • 148 Answers
it can be two things in your situation
either the battery is bad
or
the motherboard connector that is connecting to the batter is bad
call dell technical support
Posted on Feb 17, 2009
Laptop will only work when plugged into the mains, battery will not charge
your battery may be died or discharged comptletely and your power adapter are not charging.
get test the power adapter first, if it is ok, you should buy a new battery then
otherwise you should buy a new power adapter.
Aug 18, 2010 | Dell Inspiron 1525 Notebook
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 12, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 will work ok connected to mains but will not charge battery?
Check the following:
Remove the battery and re fix / Check Battery condition / Change the spare battery and check / check the charging adapter.
From the above you can't find take your laptop to the customer care.
Thank you.
May 08, 2010 | Dell Latitude C640 Notebook
My battery light is blinking lred ike it is low but is charging
According to the official dell manual for your system , this can occur when the system is too hot to charge the battery. Shut down the system and unplug it from the mains and allow it to cool to room temperature. Then , leaveing the system off , plug into AC and allow the battery to charge
If this doesnt solve the problem then it may be time for a new battery
Regards
1234s282
Apr 17, 2010 | Dell Inspiron 6000 Notebook
Cant charge battery, battery wont charge
Hello. When a battery will not take a charge do the following
1. remove the battery and take it to any autoparts store to have it tested. If is ok great. If not replace it. joe
PS if the battery is good the only cause of not charging must be a faulty charging system in the scooter. Joe
Mar 27, 2010 | Health & Beauty
New out of the box and main base wont power on when plugged in - how come?
Hello. You have to plug in your base for at least 24 hours to charge the batteries. Regards, Joe
PS - kindly rate my answer as helpful. thank you.
Feb 14, 2010 | Uniden Cordless Phone
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Batteries fully charged on pride legend fuses, isolater checked. checked all wiring appears good connection but system dead, please advise joe
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
Aug 02, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 6400 Notebook Logo
64 people viewed this question
Alun Cox
