Question about Canon EOS 600D Rebel T3i Digital Camera
Are extension tubes any good?
I'd like further zoom, can't afford a new lens, to photograph wild life. I have a 50mm F3, 18-135mm cannon lenses. Do they do macro too?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Extension tubes will not affect the zoom range. They simply allow the lens to focus closer by moving the glass farther away from the film or image sensor. I use them for my own close-up work.
The 18-135mm will let you focus down to 0.45m for a maximum magnification of about 1:4.8. True macro is at least 1:1 (lifesize) so this lens can't really be called a macro.
If you mean the 50mm f/2.5 lens, this will let you get to 1:1.
Posted on Oct 24, 2012
  • facebook2012
    facebook2012 Oct 24, 2012
    Thank you. Is that how close my 50mm gets without an extention tube?
  • kakima Oct 24, 2012
    Yes, the 50mm f/2.5 will let you get to lifesize without extension tubes. With tubes you can get much closer.
  • 4090 Answers
SOURCE: I am having trouble photographing birds. Do I use
Use the telephoto lens.. wide angle will tend to distort the image and provide too much detail( distraction) around the object of interest. Bird pictures become more interesting when they are mainly of the bird. So when you look through the lens, zoom up to the bird to the point where you have it nicely framed with none of its parts outside of the frame.
Capture the whole image.
Wide angle lens is mainly used for scenery or where you want to take a group photo or panorama.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 29, 2009
Testimonial: "Thank you for your help. Do you have any suggestions as to what settings ie Automatic or AV etc and also the ISO, shutter speed etc, Thanks"
  • 51 Answers
SOURCE: zoom lens mis-focusing. The lens
This usually happens when you are focusing on a spot which lacks details. Try aiming you focusing area to something which has clear edges
Posted on Aug 23, 2009
  • 117 Answers
SOURCE: Would this lens work with my digital canon
HI
IF the lens has a macro switch that is fixed to the
lens by two screws it is a old type lens and will not
work on digitel and it can not be upgraded
Posted on Feb 24, 2010
duane_wong
  • 6826 Answers
SOURCE: My canon ixus 75 is not turning on properly the
OK, assuming the batteries are ok, the problem is within the mechanism for the lens being too 'binding' while it operates.
Sometimes, people put their finger on the barrel of the lens when it retracts or extends.
If you reset the camera and it still does this, the camera needs to be serviced by Canon.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd500?pageKeyCode=requestRepair
Posted on Jul 28, 2010
  • 11967 Answers
SOURCE: The lense on my Cannon power shot s 80 lense will
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 21, 2011
Test chart tamrom
Front and back focus tests are good to run. You need to do it for each prime lens (fixed focal length) you have, and at your favorite focal lengths for wide angle zoom lenses too. That means on this 17-50, you would pick wide 17mm and zoomed in 50mm, and several others between. If you pick 25mm and 35mm to test, you would end up with 4 potentially different adjustments. These would apply only at 17, 25, 35 & 50mm. If you shoot at say 20mm focal length, and assume it's the same as 17 or even 25mm, you may be wrong. Too much back or forward focusing is a problem with the camera body usually - not the lens.
I'd pay attention to the lens. Look for cloudiness on the edges of the glass, scratches and fungus on glass, wetness or oil on the aperture blades, specs of dust inside the lens, etc. All of these things take away value from the lens, as they can adversely affect the image or shorten the useful life of the lens. You check these things by looking directly through the lens (not on the camera) and look at a dark background - then a light colored background to help show dirt and dust inside.
The only other thing is to look at actual images taken with the lens. Enlarge the pictures to 100% or more. Look for fuzzy edges, purple fringe edges, colors. You will see all of these issues the more you zoom in. You have to decide what it acceptable to you and what is not. Expensive lenses capture great color, are very sharp and have minimal purple fringing on hard edges (high contrast areas) in pictures.
Jan 30, 2012 | Tamron Test Chart For Tamron Af 28200mm...
I have a extension tube stuck on my Nikon lens. It's not stuck on the camera body. It's stick on the lens.
There should be a button or tab on the extension tube at approximately the three-o'clock position as viewed from the lens side, about where you would see the lens release button on a camera body. Press this button or tab, then turn the lens clockwise, exactly the same way you would remove the lens from the camera body.
Without knowing the make of the extension tube, I can't tell you whether it is a button or a tab, nor describe it in any further detail.
Jan 18, 2012 | Nikon Cameras
Focus out problem in canon 50d while using 24-70mm lens?
If by a "normal" lens, you mean a 35mm or 50mm fixed focal length - often called "prime" lens, that is to be expected. The additional and internal rotating optical elements all contribute to loss of clarity, color loss, and increased chromatic aberration that starts to become noticeable when compared to use of a prime lens. It's a trade off; less number of lenses to carry and lower cost when using wide angle zoom lenses as opposed to a prime lens for even just a few of the focal lengths offered by the wide angle zoom types.
You can minimize the unwanted effects by staying away from both the extreme wide angle and zoom focal lengths as well as the widest aperture settings. If you can stay 2 or 3 stops smaller from wide open, you can limit these destractions from your pictures. This is recommended advice for nearly every lens: Keep away from the extremes.
Jan 08, 2012 | Canon 24-70mm f/2.8 Lens
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
Jun 15, 2011 | Canon EOS 60D Digital Camera with 18-200mm...
Please tell me the best lens and flash for D3100 i m not a proffessional photographer and i rarely go to see wild animals in forest. I want to click family photographs and natural beauty
hi there,
i used d3100 a few months ago,
for your information this camera only support autofocus with built-in motor lenses
if you have interest on wildlife, you should use tele-lens whose focal length above 200mm
if Nikon lenses cost you too much, you can choose other lenses from Tamron, Tokina, or Sigma
for family photograph, the kit lens is able to do this (18 - 55mm),
for natural beauty, i myself use nikkor 50mm/f 1,8 which has great power in low light condition
hope this will help
Jan 12, 2011 | Nikon D3000 Digital Camera
Canon EF 50mm 2.5 macro autofocus broken. buy new or have it fixed ?? can u advice ?
Given the cost of this lens new, it's worth asking a repairer for an estimate. Protech Photographic, Uckfield may be able to help
Mar 16, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
I've got nikon D300, & 18 ~ 135 Nikkor lens for wild life & potraite photography I'm confusing to go Between 70-300 or 100-400 range anyone pls suggest....
The 70-300 is less expensive and lighter. The 100-400 has a longer reach. Only you can decide which factors are the most important to you.
Aug 31, 2009 | Nikon VR Zoom 80-400mm f/4.5-5.6D ED Lens
Whats the best economical lens to use for indoor photograph with
If you are new to photography in general and especially SLR photography I would suggest holding off on buying any lenses besides the 18-55mm.
The reason I suggest not buying extra lenses just yet is coz you need to get to know your camera and if you are new to SLR photography then you need to get your fundamentals right. Sure the 400D will let you shoot in full auto mode but you will really not learn much doing that and certainly not be making the most of your camera in that process and that will extend to your new lenses too.
Get used the the control, the 18-55 is a great little cheap lens with the pop up flash it will work great for most family pics. The 55-200mm is a new "cheap" lens, its been marketed as letting you go beyond 55mm thats why it starts at 55mm goes to 200mm.
Hope this helps you...
Jan 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Does not take pictures
If this is happening on a D200, it is a known issue.  If you remove and reinsert the battery it is often fine afterward.  If it is a different body then it may need repair.
Oct 18, 2007 | Cameras
Portrait
Well if 1x = 35mm, then 4x = 140mm
Sep 06, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon EOS 600D Rebel T3i Digital Camera Logo
136 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
